Has anything changed that may have caused this error in Lightburn
Using Lightburn successfully and running the Macro for using the Laser that @Julien recommended
The console error is reported as follows:
Waiting for connection…
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
error:9
G-code locked out during alarm or jog state.
[MSG:Caution: Unlocked]
ok
Homing
[VER:1.1f.20170131:]
[OPT:VNPR,14,128]
Target buffer size found
ok
ok
Starting stream
Stream completed in 0:00
File imported in 144 milliseconds
<Idle|WPos:456.000,412.000,-3.000|FS:0,0|WCO:-459.000,-415.000,0.000>
ok
<Idle|WPos:456.000,412.000,-3.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
ok
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
I have restarted my computer several times and move the X rail and Z axis to all of its limits manually but to no avail. I am using the latest copy of LightBurn version 0.9.24 in macOS Catalina 10.15.7
Any assistance in understanding what the alarm 3 message is telling me and how I might fix it would be appreciated. I have not attempted to reset anything while the machine is in motion. I have a similar enquiry on Lightburn’s forum but no assistance as yet.
Using the move tab, I can tell you that the [Home] button works as expected.
:arrow_down: button moves the Z axis left. (-X)
:arrow_left: button moves the Z axis down (-Y)
:arrow_up: button moves the Z axis left and down simultaneously (-X & -Y together)
:arrow_right: button moves the Z axis left and down simultaneously (-X & -Y together)
resolved. My fault. the Lightburn work area must be equal to the machine size, not the workpiece size. Doh! :roll_eyes:
If it’s the same problem I had, just add $X as the first line of your macro and all will work again without having to change sizes. If you’re using cut from current position and you’re not homing, this works fine.
Thank you for the information, Gary. I will give that a try because the size of the workspace in Lightburn has caught me out before. I keep wanting to make the workpiece and the work area the same size, like I do when cutting in Carbide Create.
