Having deepth control issues
I have a Shapeoko Pro, I use Vcarve pro to create projects and send gcode to Carbide Motion to run my cnc. I was having issues with my Shapeoko cutting too deep, I called in and your support person suggested I contact Vectric because your support staff say the problem is with the software.
I sent Vectric the “crv” files and all the gcode for a project. They ran everything through their support staff and showed me that the crv file and the gcode files match as far as depth of cut.
I pulled out 4 different pieces of wood and set my z to the top of my spoilboard, I then raise my router and slid the 1st piece of wood under it and using the round pin instead of a cutting bit lowered the router to the top of the material and wrote down the “Z” measurement shown on Carbide motion. I repeated this process for the other 2 pieces of wood. Below are the measurements that Carbide motion showed for the thickness of the wood pieces as well as the actual measurement as taken with my digital calipers.
Z for the top of spoilboard is 0
All measurements are in inches
Carbide measurement calipers measurement error
thin plywood 0.139 0.368 0.229
piece of trim 0.061 0.281 0.22
3/4" barn siding 0.389 0.798 0.409
rough cut plank 0.86 1.44 0.58
Thanks
Dan
Somebody needs to walk you through displaying your Grbl configuration settings, and find out what value is set for $102. However, you’re not showing a consistent percentage of error, so I’d be looking at your machine’s Z carriage mechanicals, and electricals. Check the stepper motor connection and the setscrews for the motor coupler.
Do you have the correct Z axis type defined in the configuration you sent to the controller? There are options for the original (belt), Z plus (lead screw), and HDZ (ball screw). They have different resolutions and entering the wrong one will make the Z axis move too far or not far enough. If you have a 1 2 3 block try zeroing on the spoil board and measure the block with the machine.
+1 to @Steve.Mc 's suggestion. I also have a Shapeoko Pro that was experiencing errors on the z-axis. It was the result of a loose connection in the z-axis stepper motor cable connection harness that was a known issue with a batch of machines produced for some period of time. Before this was diagnosed, I spent months thinking that it was something that I was doing wrong as this is my first CNC. Since the replacement parts have been installed, my machine has performed flawlessly. It’s nice to finally have a reliable machine that I am beginning to trust.
This may be something else, but I recommend contacting Support to see if your machine was potentially part of the flawed batch of Shapeoko Pros.
