I managed to break a few of the cable retention clips on my y-axis chain and was hoping some had a part number for the links used. I don’t expect C3D to replace something I broke but would like to fix it.
I also broke a link not being mindful. I just got a whole section. The holes in the end don’t quite match the ones C3D uses, but the links look the same.
uxcell R38 18mm x 50mm Black Plastic Semi Closed Cable Wire Carrier Drag Chain 1M Length https://www.amazon.com/dp/B01M099ZR1/ref=cm_sw_r_apan_i_E0X8FK8JG93X5MXHXNVT?_encoding=UTF8&psc=1
Thanks that seems like it will fit the x axis chain. I need the Y Axis chain that is 18 x 60.
Ah, gotcha, it was the X I replaced. I bet that some brand has the right chain though.
