HDM v3 vertical clamping surface
What is the bolt pattern (spacing) of the front vertical surface. I assume those are M5 tapped holes?
Have had the machine for several weeks and building an enclosure.
Thank You
The shop page notes:
Threaded holes on the front of the machine for edge-machining
and the announcement:
has:
M6 threaded holes and front-facing vertical clamping
The SO5 Pro has similar holes which folks have used in various mods:
@Luke or @wmoy should be able to provide the specifics if you have difficulty measuring the spacing.
Thanks Will!
Question, Do you ever sleep :slight_smile:
