If you can get the password to unlock the VFD, you should be able to manually set the spindle speed with the potentiometer on the VFD. Do you do a lot of speed changing?
Is it repeatable?
Is it repeatable?
My VFD isnât locked. When my spinderella died I changed p3 and p4 and had speed control with the potâŚ
Awesome!  How does that work?  I.E. What are the spindle speeds at the minimum and maximum pot settings?  Can you please correct/augment the attachment with your VFD parameters?
VFD Function Parameters.pdf (95.5 KB)
Good to know, more learning for me.
