We were discussing HDPE on here the other day. Here is a good example of its durability for outdoor projects. I cut these for our pool back in April (I think). They’ve sat out in the direct sun of Georgia all summer long. They look like the day I cut them. I used a 1/4” O Flute bit.
I’ll cosign that comment. I figured we’d at least need to clean our ColorCore signs periodically but the rain basically is enough. Half a decade of 95 in the summer and -30 in the winter and they still look brand new.
I’d say it’s important to bring units temperature instability and the amount of warpage a 40f degree temp swing can cause if you don’t allow it to float.
You just have to keep this in mind when hanging the sign don’t screw it ok more than 2 locations.
I use 1/4” hdpe for work bench tops they are secured by screws in 12” grids. It was installed on a 70 degree day. If I turn the AC off in my shop and it gets to 95 degrees I’ve got 1” lifts between the. Screws.
My first experience with HDPE was in the underground utilities.
We used HDPE fused pipe to put in water, sewer, telecom, power, and gas.
Some cool features with this material is that you can heat and weld it together the way the factory explained it was the molecules are J shaped the heat makes them straighten out then as it cools they return to their J shape locking at the fuses on a molecular level.
