The HDZ HD eccentric nuts should have threads right? or am I crazy?
I am confused. I think they have threads. I’m about to go take one off lol
Yes the bottom HDZ eccentric nuts for the V wheels have threads.
The hdz has two threaded nuts at the bottom and two at the top without threads. Any you use for other v wheels will have threads.
Yes, the eccentric nuts should have threads — if they didn’t they’d be eccentric spacers as were used for the Shapeoko 1.
If you haven’t already, please let us know about this at support@carbide3d.com and we’ll work it out with you.
I guess I’m just unlucky. Mine have no threads, smooth as a babies butt inside. They’re going to send me new ones.
They might be the unthreaded eccentric nuts used in the “easy-tram” portion of the router mount. Check and see if you have the threaded ones there and can switch them out.
Damn, good thought, I will check in a bit. I’m gonna feel real dumb if they are there.
This was it, I’m such a dummy. Since I have the 80mm mount, I didn’t use the easy tram mount.
No worries! It just so happens that I had a 30 second freak out over the same exact thing a little while back…and it popped into my head when seeing your post. Glad I could help!
Just got my HDZ read your post… Saved me an email to support!
