Steadiguy
(K. Smith)
February 10, 2020, 7:04pm
#1
Hey guys.
Just installing HDZ and having an issue with the X motor. It doesn’t line up with the pulleys as you can see in pict, It looks like you have to turn the spindle gear around so it lines up, don’t remember seeing that anywhere in the manual:)
Any help would be much appreciated!
WillAdams
(William Adams (Carbide 3D))
February 10, 2020, 7:06pm
#2
Could you have swapped the X and the Z motors?
If that’s the case and you’ve already installed the X, just loosen the pulley set screws and remove the pulley and reorient.
See: https://docs.carbide3d.com/shapeoko-faq/shapeoko-3-how-to-check-the-pulley-set-screws/
If you have any issues, contact us at support@carbide3d.com and we’ll do our best to work this out with you.
Steadiguy
(K. Smith)
February 10, 2020, 7:20pm
#3
Thanks Will, you rock! Thats exactly what happened, aaah the beauty of getting old:)
system
(system)
closed
March 11, 2020, 7:20pm
#4
