Is there parts available for the HDZ.I unfortunately been chasing an issue that I think I found… the mounting hole on my HDZ PLATE is stripped on the first few threads.
I removed the router .had to loosen the 4mounting screws for the linear bearing to slide it down so I could inspect and re-tap the hole.
6mm 1.0 thread .
Seems to have worked but when I was sliding the bearing back up to re- secure it if
Course it slipped and made it down far enough for some of the balls to fall out…
So I need a linear bearning as well.
I took it apart . It’s easy enough …
I have 122 bearing balls but I have no idea if that’s all of them or not?
The only way for me to verify would be to take another one apart and see how many are in the good ones but I don’t want to do that so is there any source for the bearings I see some of them for sale but they don’t look exactly like the part that’s on here?
Bearing part number
Is HGH15CA. 190A07Z-342 is the # on the bearing.
