I’m almost done installing my HDZ. I’m using the Suckit dust boot & the proximity sensors. Per the instructions, when using the Suckit ears:
If you are using the proximity sensor kit, you need to align the x axis switch so it triggers from the rear - not the HDZ main body.
I’m not following this. I have the X axis proximity sensor in the ‘normal’ position and the Suckit ear hits the proximity sensor. Where does it move to?
It just dawned on me, at 12:15 AM when I should be sleeping - is this a typo? Should it be ‘triggered from the ear’, not ‘triggered from the rear’? That makes sense to me.
