Here is my question if anyone can help me about what use to the 4 piece of Black Sledge that comes with the HDZ package version 3.3 ?
Thank you
It’s for the ball carriages if you have to slide them off the guides/rails, otherwise you might make a mess of tiny steel ball-bearings.
@BrokenEndmill is correct, see pg. 14 of Getting Started with Carbide Machines
The black plastic sledges are used on the off chance you have to remove a slider block. As the block slides off a rail, slide the sledge into the block. Please DO NOT remove a slider block unless advised to do so by support— ball bearings can fall out
Thank you for the perfect point and reply
Thank you William ! I just seen it it’s helpful
