HDZ Z axis going wrong direction
Just finished installing my Shapeoko Pro and installed my HDZ Z axis upgrade. The Z axis goes in the wrong direction when trying to initialize the machine.
My wiring seems correct. I removed the plate to see if I installed something upside down but doesn’t look that way.
Can I get some help with on this?
Looks like I fixed it with /$3=4
Usually when a new machine goes the wrong way it is a configuration issue. The Shapeoko Pro came with an Z-Plus which moves backward compared to an HDZ. Does you CM have the option in Configuration for a Pro with HDZ. If not you may need to upgrade CM to a version that supports Pro with HDZ.
Please update to the latest version, and send the correct configuration for your machine — if that doesn’t work right, let us know at support@carbide3d.com
