I’m trying to continue an operation at line 9000 after pausing and continuing the next day. I’ve looked at some posts and the wiki on reddit and it seems like a straightforward process, only the example preamble and safety height on the example Gcode and mine are completely different. Can someone help me identify the preamble and where the safety height retract is?
I tried cutting from what I think is the preamble, but I end up with arc endpoint errors:
(1001)
(T5 D=3.175 CR=0 - ZMIN=-12.7 - flat end mill)
G90
G17
G21
(When using Fusion 360 for Personal Use, the feedrate of)
(rapid moves is reduced to match the feedrate of cutting)
(moves, which can increase machining time. Unrestricted rapid)
(moves are available with a Fusion 360 Subscription.)
G28 G91 Z0
G90
So would I change the coordinates of the G0 line 19 in the preamble to X88.988 Z-0.136 I-1.012 J0 of line 8732?, and then change line 22 in the preamble to Z0.0?
Yes, change the coordinates in line 19 to the same XY coordinates in the first line you intend to cut.
You aren’t showing line 8732. X88.988 Z-0.136 I-1.012 J0 is a circular/helical move. It would be easier to start at a linear move. Even better a rapid positioning move. In this example, cut it at the redline, and then edit line 19 to match line 8756.
