Help with BitSetter
I have been trying to set the spot for my BitSetter although when i go into the settings there is only a spot to enable BitSetter and not a spot to set the specific location of where I jogged the router to. When I do have it go to the BitSetter location it goes to a random spot and wants to dig into the table. PLEASE HELP!! Also its on a Shapeko 4
Adjusting the programmed position of the BitSetter is done in the Setup Wizard option shown when you first load up Carbide Motion (assuming you’re on v6).
