New to the group and still figuring things out–slowly.
I want to duplicate a missing corner piece from an old headboard. It’s basically a quarter circle with outside diameter of 5" and inside diameter of 3" with radiused edges and a 1"inch x 1/4" flat on top.
I sort have the outline done and know what the profile should look like. On the Round Modeling toolpath I don’t see any way to specify the radius of that rounding unless somehow restricting the height is supposed to do that. Even if I figure that out, the ends do not need to be rounded, but square.
If someone could walk me through some of that, I should be able to apply it to other projects in the future.
To model this you want to extend the vectors outside of the intended bounds, and make the width of each section 1". The angle & height will determine the radius. Angle 90° and height 0.5" will make the radius 0.5"
You really don’t need to model the flat center section as that can be achieved with 2D
The only portions that need to be cut with 3D are the rounded shapes.
3D toolpaths calculate with the center of the cutter on the boundary, so you’ll want boundaries offset by the radius of the ball mill. I’ll use a 1/8" ball, so offsets are 1/16"
I designed the part, stock & model 0.8125 height, your 0.750 plus the radius of the ball mill so I can cut the 1/16" below the bottom edge of the part to get the tool tangent at the bottom.
Add 0.0625" base to the model components.
So I machine around the center section down to 0.25"
Then machine the rounds with a 3D path
I also created dummy paths to trim the outside
Thanks! I was able to do a pretty good job with a bandsaw and a router. Just knowing that the CNC is capable of doing it perfectly makes me wish I had done it that way.
Thanks so much! When I get a chance I’ll go back and read through this slowly a few times and see if I can understand it. Not sure I get how to 2D model on top of a 3D, but I’ll work with it for a while, maybe something will click…
Thanks for the tutorial. Not said but it seems the last operation for the 2D tool path for the 1” wide x .25” flat top (Ogee) cut used a square end mill correct? At least the simulation indicates that based on the 90 deg inside corner.
Yes. This will give you a sharper corner at the top of the radii. I used a really big, unrealistic, end mill just to remove more material for the simulation.
