My 4 y/o granddaughter is obsessed with all things unicorns. So I am looking to make a sign for her bedroom door, and could use a little help.
So I plan to cut pockets, and use resin tinted different pastel colors for the unicorn.
For the hair (three wavy vectors going from right to left), what would be the best way to split these in to 3 separate vectors so that the three different colors don’t run together? Is there a better way to do these 3 pours that I’m just not thinking of?
They are black, which suggests that they are already 3 separate vectors.
If you want them to fit tight to each other, carve & pour one color at a time.
You could create a small gap between them by tracing the 2 dividing lines & offsetting and using that to trim, or join into a closed shape & subtract from each section.
You could just offset the center section inward, then edit the right end to match the offset shape around the flower. Or offset the center section outward & use that offset to trim the top & bottom sections.
