Can anyone help me figure out why my cut suddenly stopped, I can not even get it to where I can hit start and resume
I would:
- take note of the line you’re on
- turn off the router
- turn off the machine
- reboot the computer
then edit a copy of the file to resume at that point as noted at:
https://wiki.shapeoko.com/index.php/FAQ#Continuing_a_cut_which_is_interrupted
and power up the machine, connect, and then send the balance of the file to the machine.
Why? 99% chance it’s a USB Disconnect. You can search for it… a common issue/problem with the Shapeoko…
PS Be VERY Careful cutting a file as Will said. It can be done, but I usually recommend it for a very experienced CNC operator…one that can read gcode and knows all the modal commands are in place.
Also, I HIGHLY recommend that you set the Z about an inch (25mm) and dry run the (edited) program first.
I can confirm that - because I tried to do this and failed. Clearly I wasn’t in the…
…bracket!
Thanks a lot appreciate the feed back
