Running CM 4.0.416 on my XL. When I’m lowering the bit to zero it to the work piece, I sometimes over do it, causing the Z-axis to skip. To recover I have to Z-up and run a Homing Cycle to be sure the unit hasn’t lost any steps. To do this now, the only way I see is to re-power the XL unit, reconnect to the software, THEN manually issue a re-homing request. How about a button somewhere in the user interface to Z-up, and re-home the cutter in one step? Thanks.
Isn’t there a homing cycle button on the rapid position screen?
While not a button, one can re-home by going to the MDI and sending
$H
