So I faced this issue as I first time powered on my Shapeoko Pro. And once again today like a week after I assembled the machine. The machine fails to do homing cycle or something else related to bad connections with motor/limit switches.
I’ve seen many threads about errors in middle of the job. I am pretty sure it has to do with the connectors.
Carbide3d uses really bad quality connectors on its machines. This needs to be changed!
Here’s a video for example:
I will remove all the connectors and solder the wires together because my next project will be an enclosure and I just can’t have any connector issues when the machine is inside the enclosure.
Fair enough, but Carbide 3D supplied me with a new CM control board when the BitRunner connector became loose on the board, and that’s probably the most expensive, single component of the whole system, at least for the SO3.
