Hey everyone.
So I just set up my shapeoko and everything was going fine. I sent it home and decided to try out my first project. I was trying to set my zero and I noticed the jog function was missing in carbide motion. I read that it will only let you jog when you send it home so I decided to home it again. That all worked fine but now after it goes home itll move to the front center of my table and tell me I need to put a tool in the spindle. Then it moves back home and my Z drops into my table. Not sure where I messed up but any help would be appreciated.
Power up, connect to the machine, go to Settings, then clear the checkbox which enables the BitSetter — that should allow the machine to initialize as expected.
Once the machine has initialized successfully you can enable and configure the BitSetter.
