Homing problems Shapeoko 3 XL Belt drive
Just bought a new control panel for the used Shapeoko 3 XL Belt drive I recently purchased.
I’m having problems homing…when I try to set up it shakes and grinds on the Z axis with no movement in X or Y. I also bought and connected a BitZero 2.0 and have now also
connected that to the reserved spot on my board which is 2.4g
I’m more than a little frustrated that I can’t speak with someone especially given the money I just spent to upgrade.
The debug reads as follows:
Machine: Shapeoko
GRBL Version: 1.1f
Carbide Motion 640
Machine Controller State: INIT
Grbl Cycle: Idle
“bitRunnerEnabled”: false,
“bitSetterEnabled”: false,
“bitSetterX”: 0.0,
“bitSetterY”: 0.0,
“bitZeroType”: 0,
“connection”: 1,
“lastConfigSent”: 0,
“lastProbeIndex”: 0,
“lastSizeOption”: 1,
“odometer”: ,
“showCarbideRouterRpm”: true,
“spindleType”: 0,
“travelX”: -830.0,
“travelY”: -430.0,
“travelZ”: -100.0,
“version”: 0,
“webhooks”: ,
“workOffsetX”: 0.0,
“workOffsetY”: 0.0,
“workOffsetZ”: 0.0
0 = 10, Step pulse, microseconds
1 = 255, Step idle delay, milliseconds
2 = 0, Step port invert, mask
3 = 6, Direction port invert, mask
4 = 0, Step enable invert, boolean
5 = 0, Limit pins invert, boolean
6 = 0, Probe pin invert, boolean
10 = 255, Status report, mask
11 = 0.02, Junction deviation, millimeters
12 = 0.01, Arc tolerance, millimeters
13 = 0, Report inches, boolean
20 = 0, Soft limits, boolean
21 = 0, Hard limits, boolean
22 = 1, Homing cycle, boolean
23 = 0, Homing dir invert, mask
24 = 100, Homing feed, mm/min
25 = 2000, Homing seek, mm/min
26 = 25, Homing debounce, milliseconds
27 = 3, Homing pull-off, millimeters
30 = 24000, Max spindle speed, RPM
31 = 0, Min spindle speed, RPM
32 = 0, Laser mode, boolean
100 = 40, X steps/mm
101 = 40, Y steps/mm
102 = 40, Z steps/mm
110 = 10000, X Max rate, mm/min
111 = 10000, Y Max rate, mm/min
112 = 5000, Z Max rate, mm/min
120 = 500, X Acceleration, mm/sec^2
121 = 500, Y Acceleration, mm/sec^2
122 = 400, Z Acceleration, mm/sec^2
130 = 845, X Max travel, millimeters
131 = 850, Y Max travel, millimeters
132 = 100, Z Max travel, millimeters
Queue Empty
Help!
On support, we responded asking for a photograph of your controller — we will work with you on that basis in the support queue.
When initializing the first thing that happens is the Z homes. If the Z does not home the X and Y do not start.
If you have a belt drive Z then remove it and inspect the belt and the tensioning mechanism. The belts can come loose or get stripped over time.
The Belt Z on an SO3 works but a Z-Plus is much better. However to upgrade to the Z-Plus you must also have proximity switches. Both the Z-Plus and the proximity switches are worth the investment to make your SO3 last a long time into the future.
I started with a belt Z but upgraded to an HDZ and that was one of the best upgrades I ever did.
