Is there a way to “permanently” set the “Has Homing” parameter? It works for me, thanks for the help, but I have to reset it to “true” every time I restart the app.
@cobalt60 the command $22=1 set it permanently for me.
@ApolloCrowe the strange homing behavior has not changed. The Z axis looks to home properly; as the gantry travels to the back and the X moves to the right, the Z will move up to the homing switch and then back off slightly (which is, I suspect, correct behavior). Once the gantry moves toward the back of the machine, both the X and Y stop short of the limit, never touching off the switches. Then CM just sits there and waits. Here’s a video of what happens:
I can, after the failed homing attempt (without moving anything), close CM, switch power off my XXL, power back on, run CM, connect my XXL, jog and home; then homing works. It’s always the first homing attempt after sitting a while off that fails.
