How can i use marker, then switch to endmill without losing XY
Hi All,
long time user, 1st time emailer…
Is it possible to use the carbide marker holder to mark (hardware locations), then switch bits to endmill to cutout shapes/letters?
I’m not able to wrap my brain around how to keep my XY the same since the marker doesn’t line up with the center of the chuck.
Is it feasable?
Thanks much for any insight…
Add a piece of paper off to the side, use the marker to make a mark on it, and note the XY Positions.
Change to the pointiest V-tool you have and jog until the tip of the tool is at the center of the mark, note the new position.
Rapid position to the current XY zero, then jog off by the difference between the two positions and re-set zero so that the new tool now matches.
