I just tested a path created in V6, output G-Code, then open in V7, save paths, use website to convert. Then sent the .c2d to CM & output G-Code. All 3 are identical except for the first line (file names were different), and the toolpath name line.
In V7 (both cases) the toolpath name was empty. ()
If fenrus is looking for the “Pocket” and “Vee-Carve” in the toolpath name, his utility won’t find them.
and for the record, unless testing something like this… this will be the last time I:
save the .c2d
send to google drive
go to shop & retrieve it from google drive
move it to the project folder
start my machine
connect CM
initialize the machine
open the .c2d file
save the G-Code
copy file up to google drive
shut down machine
go back to office
retrieve file
just to get a G-Code file.
I will continue to test V7 (for a while) in the hopes that the developers come to their senses & revert the change to prevent saving G-Code. In the meantime, I’ll be using something else to create G-Code.
