How to delete a couple of points carbide create
I got this file from someone and it’s got these points that keep wanting to be drilled out. I’d like to delete them. I haven’t had any luck. I’m kinda new to the program.
SELECT them in Design and delete. You cannot edit a design from TOOLPATHS.
If these are simply nodes or random points, SELECT it, got to NODE EDIT and hit D.
Those are Drill points.
The problem is you have the outlines of the clamps selected and included with the Drilling Toolpath 2 — if you edit it it will show as 8 vectors selected/associated w/ it.
e.g.,
2 objects:
With both selected, if one assigns a Drill Toolpath:
one gets the second point.
If one then associates only the circle w/ the Drill toolpath:
the little extra point goes away:
thanks for your help Will!
