I have been adding various bits that I have into my tool database, but have found that the automatically filled values such as flute length do not match my bits and need to be changed. I have not been able to figure out how to edit this information so far, is it possible to edit this or am I stuck with what Carbide Create populates?
These values would need to be edited in the underlying .csv file.
Carbide Create | About | Open Data Directory
then edit the .csv files in the tools directory
When you create the new tools in CC you can then do as @WillAdams suggested and add anything you want or change things. Just be sure to save the spreadsheet file as a .csv file and not the native spreadsheet file that it will default to when saving. CC can only read the .csv file format and not a spreadsheet file format.
Thanks gdon_2003 and WillAdams for the information. I’m trying to open the .CSV file right now, but need to find and install a program to edit the file as I currently only have a .CSV viewer. I’ll update this post once I get into editing it.
Your advice worked flawlessly! I have been able to go in and modify tool data as needed to accurately represent each bit. Thank again!
