The title says it all. I would like to raise the letter within the text line.
How to edit text to add a superscript as in McGuinness but to raise the letter C so it floats higher
Convert to Curves as described in:
https://carbide3d.com/blog/merging-script-fonts-in-carbide-create/
then shift the individual letter as desired.
Alternately, use a tool which has this facility for text, then convert to paths, save as SVG and import.
Thanks Will. Much appreciated!
