bmcdowel
(Bryan Mcdowell)
July 8, 2025, 12:02am
1
Asking the group for examples of how to flatten/surface the slotted wasteboard with the t-track on the S03 XXL.
I have seen some do it by manually controlling the spindle in vertical passes up and down the length of each mdf panel.
I also have one from Myers woodshop for the threaded wasteboard that does a pocketing pattern to surface the the wasteboard.
Is it possible to raster profiles as opposed to the pocket operation in Carbide Create like you can in VCarve?
Thanks,
Bryan
WillAdams
(William Adams (Carbide 3D))
July 8, 2025, 12:07am
2
You can draw up arbitrary toolpaths as shown at:
I draw up such a toolpath for a single slat, pick the one with the deepest gouge, then rung it on that until the slat is smooth, then re-run it at that depth on all the other slats.
Ed.E
(Ed)
July 9, 2025, 12:24am
3
Carbide Create Pro has a Facing tool path built in that works nicely.
system
(system)
Closed
August 7, 2025, 12:03am
4
