How to insert CC file into new drawing?
I’m trying to insert some web dxf images into my existing drawing. Can’t figure out how to do this.
thanks
Make sure that you’re running a current build, then select the Design tab, then deselect everything. Under Import at the bottom there should be two icons, one for the Library of pre-designed elements (on the left), the other, “Import External File” on the right will allow you to open files, adding them to the current objects.
William
Great, thanks. Thought it wasn’t working but reset view made them show up.
