Hello,
I’m using Carbide Motion
My goal is to match the reported position of a running program in the LOG to a moment in time.
For example:
(93618): <- <Run|MPos:-44.605,-203.940,-33.095|Bf:13,128|Ln:23|FS:102,0>
The position in xyz is -44.605,-203.940,-33.095
But I’ve found no way to know at what time does that position ocurred.
After many tests I believe the positions are reported at regular intervals, however, I can’t really know for sure if that is precise enough for me to asume that X ammount of time passed between samples.
Current calculation is 20.74 ms between samples, which seems like an odd value.
Is there a way to enable a timestamp or otherwise know precisely the moment at which each position occurred?
PS. It doesn’t need to be carbide motion, maybe another software has a more detailed log that I can use.
Thanks!
