We will assume that there is a basic cut of 1/8" deep using the V tool along the perimeters and a pocket which clears the balance of the material, so we draw a line to represent that bottom:
Cut these as a Contour and as a pocket (A V-carve toolpath w/ pocket clearing could be used, but I believe this will be conceptually clearer and make for more efficient cutting:
(it must be drawn from the two original circles to ensure that it is vertical/aligned w/ the center of the circles — if need be, use the Align tool to ensure that the circles are aligned with the Stock)
At this point, there are two options, make the ideal version and select alternating instances and have two toolpaths, or inset the radial lines slightly and use one toolpath — we will do the former as conceptually easier and more correct.
Thank you for the fantastic tutorial @WillAdams. Every time I read through a tutorial I find something that reaffirms my ignorance of CNC. I’ll not admit to my ignorance but it was found here:
