I have carbide create build 756. How do print a drawing?
I would recommend updating to the new stable 831:
which adds a File | Print command:
Note that this is early days yet, so if you have a file which doesn’t print as expected, please let us know — I’ve had best results by setting the Stock size to match the print are of the page, then arranging things as desired on that — using a special layer for that might be one approach, at least for now.
William,
Thank you very much.
Bob Sullivan
Freeport, FL
