How to, XY axis verification
I finally got some time iu of my busy schedule to work on my Shapeoko 3 XXL.
Is there a way to verify the X Y axsis for squareness given the following thoughts:
  1. Lead pencil mounted to the spindle collet.
  2. Written program to draw a 1 inch line intersecting cross at 4 corners. The longer the distance, the more accurate a measurement can be achieved.
  3. By measuring the X distance and Y distance, the diagonal can be calculated.
I am not at the programming stage as this is all new to me. A written program of X length and Y length, then the diagonal can be verified for squareness.
I have leveled all 4 corners to within 0.001" using a dial indicator.
I have trammed the router spindle to within 0.001" using a tramming dial indicator.
All I have left is to check for squareness, verify stepper increments with a dial indicator on XYZ axsis then use a shaper to flatten out the waste board.
Any help will be Greatly Appreciated in moving forward.
