I have looked through this a bit and not found a straight forward answer. I installed the homing switches when I first got my machine and haven’t trusted that they worked enough to try them more than once. the first time i tried homing i had to kill carbide motion because it was just skipping on the belt at the back corner of the machine. I just wondered if there was a way to get logging output for when the switches are engaged before I try again. I am able to test on my voltmeter and confirm that the switches function, just not seeing anything from the motion software.
Have you enabled homing in carbide motion? If you load carbide motion and connect - click jog and it brings the jog screen up they are not enabled. When enabled it will ask you to home machine first.
The way I did it was bring the machine to front left corner, router low. Begin homing and press the z axis one, then the x then the y.
Oh wow. I will have to try both these options. I had started working with Ultimate gcode sender but without too much success. Wasn’t able to get feedback from the switches. I’ll have to take another crack at it. I might just try triggering it on my own. It didn’t move too fast for you @Luke?
