Does anyone have the exact spacing between the 3 holes of the hybrid table extrusion on the X axis? I tried to measure using various methods(hole guages, pins…etc) but I’m getting inconsistent results due to some play in the hole dimensions. I guess the two outer holes are supposed to be 50mm apart and the 3rd is in the center but I cant be sure since the Y spacing is a odd fractional number in inches (12 2/3").
