Timman
October 8, 2015, 1:26am
1
Hey Guys,
I am the proud owner of Shapeoko 3 0813, I am running V-Carve Pro & Inventor Pro 2015. I am having all kinds of trouble with the machine cutting to deep. The G code is fine, I have checked and double checked it. I was just wondering if anyone else was having the same problem. I have scoured the net for answers to the problem, everything I have found I have checked. The Belts, RF Noise, The Code, you name it I have checked it. Someone please give something I can use.
WillAdams
(William Adams (Carbide 3D))
October 8, 2015, 1:43am
2
Which spindle are you using?
What endmill? Try using a 2-flute straight to start
How tight did you manage to get the Z-axis belt? It took me a couple of tries to get mine tight enough — finally had to use a small pry bar: http://www.shapeoko.com/forum/viewtopic.php?f=37&t=6765
mbellon
(Mark Bellon)
3
In VCarvePro one sets the Z0 to be the top or bottom of the stock. Please tell us which you chose.
When you set up the machine, how did you set Z0 on the machine? Touch top of stock? Top of spoiler?
Can you please post the G code? Can you please export your CAD as an IGES file and post it?
Timman
October 8, 2015, 2:00pm
4
I am using the DW611
The Belt seems very tight to me, but I am sure there is room for a little more.
Timman
October 8, 2015, 2:03pm
5
I am setting the Zero at the top of the stock.
I set Z0 by touching the top of the work piece.
I am using .250 2 flute endmill
My stock is 1 inch Pink foam.
mbellon
(Mark Bellon)
October 8, 2015, 2:15pm
6
thanks! Can you post an IGES of the CAD please?
Timman
October 8, 2015, 2:52pm
7
I can post the IGES later today, at the office right now.
The problem seems to arise when I place a spoil board under the stock being cut. No matter how I zero the first plunge will go thru the work piece and the spoil board.
For example: last night I tried a profile cut in 1 inch foam board with 1/2 foam board spoil under it.(Very simple, just a 2’’ circle) My profile cut was set for 1 inch stock and a 1 inch deep cut. I zeroed at the top with the spoil board in place, the firs plunge goes all the way to the bed of the machine.
Is it something I am doing wrong in the set up?
WillAdams
October 8, 2015, 3:00pm
8
What method are you using to set zero?
Timman
October 8, 2015, 3:25pm
9
I am touching off on the top of the work piece. I use the center of my work and Zero all from there.
WillAdams
October 8, 2015, 4:02pm
10
Which command / comm/control program?
Timman
October 8, 2015, 4:14pm
11
I am using Carbide Motion, I even downloaded it again last night thinking that may help.
WillAdams
October 8, 2015, 7:00pm
12
Mystified then.
As I noted, I had problems w/ increasing cut depth due to insufficient belt tension — another mechanical thing to check would be that the pulleys aren’t loose — which length belt do you have? This was changed after an early batch of bad belts.
Check the DIP switches — toggle the one for the motor current a few times?
Have you tried a straight cutter to eliminate the possibility of the machine getting pulled down into the cut?
I’d try a different file as a test — there’s a circle-diamond-square test file on the Shapeoko wiki http://www.shapeoko.com/wiki/index.php/Calibration_and_Squaring_the_Machine#Diamond_Circle_Square_Test — try cutting that?
If you’re still having problems after all that, contact support@carbide3d.com and see what they suggest.
mbellon
(Mark Bellon)
October 8, 2015, 7:18pm
13
This is a big of a mystery. Let’s see the CAD file, just in case there is something there.
Could you also post the G code?
Timman
October 8, 2015, 8:21pm
14
Will,
Thanks for you suggestions.
I have checked my pulleys, all is tight.
I have only had my Shapeoko 3 for about a month, not sure when the bad batch of belts came out.
As for Dip Switches, the control board that came with mine does not have any?
As for the cutter getting pulled in the work, I would not think so. I am only cutting Pink Foam Board from Home Depot.
I am beginning to wonder if I just have a bad board, I have also changed out the USB cable three times and still the same thing. I have also powered the Machine from 2 different circuits to see if that made a difference, No Change
Still Plunging all the way into the bed.
Timman
October 8, 2015, 8:29pm
15
One more thing guys that may help and solve the problem,
When I load a job,
I create in V-Carve Pro
Set Z to the top of the work.
At the start of the job, the Z retracts up until it crashes into the stops, them the job begins. I will post the code shortly.
Timman
October 8, 2015, 8:35pm
16
T1M6
G17
G0Z1.7000H1
G0X0.0000Y0.0000S12000M3
G0X0.0000Y1.6250Z0.2000
G1Z-0.1250F30.0
G1X0.0206Y1.6249F100.0
X0.0412Y1.6245
X0.0620Y1.6238
X0.0829Y1.6229
X0.1038Y1.6217
X0.1249Y1.6202
X0.1460Y1.6184
X0.1672Y1.6164
X0.1885Y1.6140
X0.2098Y1.6114
X0.2312Y1.6085
X0.2527Y1.6052
X0.2742Y1.6017
X0.2957Y1.5979
X0.3173Y1.5937
X0.3389Y1.5893
X0.3605Y1.5845
X0.3821Y1.5794
X0.4038Y1.5740
X0.4255Y1.5683
X0.4471Y1.5623
X0.4688Y1.5559
X0.4904Y1.5492
X0.5120Y1.5422
X0.5336Y1.5349
X0.5552Y1.5272
X0.5767Y1.5192
X0.5982Y1.5109
X0.6196Y1.5023
X0.6409Y1.4933
X0.6622Y1.4840
X0.6833Y1.4743
X0.7044Y1.4644
X0.7254Y1.4541
X0.7464Y1.4435
X0.7671Y1.4325
X0.7878Y1.4213
X0.8084Y1.4097
X0.8288Y1.3978
X0.8491Y1.3855
X0.8692Y1.3730
X0.8892Y1.3601
X0.9090Y1.3469
X0.9287Y1.3335
X0.9482Y1.3197
X0.9675Y1.3056
X0.9866Y1.2912
X1.0055Y1.2765
X1.0242Y1.2616
X1.0427Y1.2463
X1.0610Y1.2308
X1.0791Y1.2150
X1.0969Y1.1989
X1.1146Y1.1825
X1.1319Y1.1659
X1.1490Y1.1490
X1.1659Y1.1319
X1.1825Y1.1146
X1.1989Y1.0969
X1.2150Y1.0791
X1.2308Y1.0610
X1.2463Y1.0427
X1.2616Y1.0242
X1.2765Y1.0055
X1.2912Y0.9866
X1.3056Y0.9675
X1.3197Y0.9482
X1.3335Y0.9287
X1.3469Y0.9090
X1.3601Y0.8892
X1.3730Y0.8692
X1.3855Y0.8491
X1.3978Y0.8288
X1.4097Y0.8084
X1.4213Y0.7878
X1.4325Y0.7671
X1.4435Y0.7464
X1.4541Y0.7254
X1.4644Y0.7044
X1.4743Y0.6833
X1.4840Y0.6622
X1.4933Y0.6409
X1.5023Y0.6196
X1.5109Y0.5982
X1.5192Y0.5767
X1.5272Y0.5552
X1.5349Y0.5336
X1.5422Y0.5120
X1.5492Y0.4904
X1.5559Y0.4688
X1.5623Y0.4471
X1.5683Y0.4255
X1.5740Y0.4038
X1.5794Y0.3821
X1.5845Y0.3605
X1.5893Y0.3389
X1.5937Y0.3173
X1.5979Y0.2957
X1.6017Y0.2742
X1.6052Y0.2527
X1.6085Y0.2312
X1.6114Y0.2098
X1.6140Y0.1885
X1.6164Y0.1672
X1.6184Y0.1460
X1.6202Y0.1249
X1.6217Y0.1038
X1.6229Y0.0829
X1.6238Y0.0620
X1.6245Y0.0412
X1.6249Y0.0206
X1.6250Y0.0000
X1.6249Y-0.0206
X1.6245Y-0.0412
X1.6238Y-0.0620
X1.6229Y-0.0829
X1.6217Y-0.1038
X1.6202Y-0.1249
X1.6184Y-0.1460
X1.6164Y-0.1672
X1.6140Y-0.1885
X1.6114Y-0.2098
X1.6085Y-0.2312
X1.6052Y-0.2527
X1.6017Y-0.2742
X1.5979Y-0.2957
X1.5937Y-0.3173
X1.5893Y-0.3389
X1.5845Y-0.3605
X1.5794Y-0.3821
X1.5740Y-0.4038
X1.5683Y-0.4255
X1.5623Y-0.4471
X1.5559Y-0.4688
X1.5492Y-0.4904
X1.5422Y-0.5120
X1.5349Y-0.5336
X1.5272Y-0.5552
X1.5192Y-0.5767
X1.5109Y-0.5982
X1.5023Y-0.6196
X1.4933Y-0.6409
X1.4840Y-0.6622
X1.4743Y-0.6833
X1.4644Y-0.7044
X1.4541Y-0.7254
X1.4435Y-0.7464
X1.4325Y-0.7671
X1.4213Y-0.7878
X1.4097Y-0.8084
X1.3978Y-0.8288
X1.3855Y-0.8491
X1.3730Y-0.8692
X1.3601Y-0.8892
X1.3469Y-0.9090
X1.3335Y-0.9287
X1.3197Y-0.9482
X1.3056Y-0.9675
X1.2912Y-0.9866
X1.2765Y-1.0055
X1.2616Y-1.0242
X1.2463Y-1.0427
X1.2308Y-1.0610
X1.2150Y-1.0791
X1.1989Y-1.0969
X1.1825Y-1.1146
X1.1659Y-1.1319
X1.1490Y-1.1490
X1.1319Y-1.1659
X1.1146Y-1.1825
X1.0969Y-1.1989
X1.0791Y-1.2150
X1.0610Y-1.2308
X1.0427Y-1.2463
X1.0242Y-1.2616
X1.0055Y-1.2765
X0.9866Y-1.2912
X0.9675Y-1.3056
X0.9482Y-1.3197
X0.9287Y-1.3335
X0.9090Y-1.3469
X0.8892Y-1.3601
X0.8692Y-1.3730
X0.8491Y-1.3855
X0.8288Y-1.3978
X0.8084Y-1.4097
X0.7878Y-1.4213
X0.7671Y-1.4325
X0.7464Y-1.4435
X0.7254Y-1.4541
X0.7044Y-1.4644
X0.6833Y-1.4743
X0.6622Y-1.4840
X0.6409Y-1.4933
X0.6196Y-1.5023
X0.5982Y-1.5109
X0.5767Y-1.5192
X0.5552Y-1.5272
X0.5336Y-1.5349
X0.5120Y-1.5422
X0.4904Y-1.5492
X0.4688Y-1.5559
X0.4471Y-1.5623
X0.4255Y-1.5683
X0.4038Y-1.5740
X0.3821Y-1.5794
X0.3605Y-1.5845
X0.3389Y-1.5893
X0.3173Y-1.5937
X0.2957Y-1.5979
X0.2742Y-1.6017
X0.2527Y-1.6052
X0.2312Y-1.6085
X0.2098Y-1.6114
X0.1885Y-1.6140
X0.1672Y-1.6164
X0.1460Y-1.6184
X0.1249Y-1.6202
X0.1038Y-1.6217
X0.0829Y-1.6229
X0.0620Y-1.6238
X0.0412Y-1.6245
X0.0206Y-1.6249
X0.0000Y-1.6250
X-0.0206Y-1.6249
X-0.0412Y-1.6245
X-0.0620Y-1.6238
X-0.0829Y-1.6229
X-0.1038Y-1.6217
X-0.1249Y-1.6202
X-0.1460Y-1.6184
X-0.1672Y-1.6164
X-0.1885Y-1.6140
X-0.2098Y-1.6114
X-0.2312Y-1.6085
X-0.2527Y-1.6052
X-0.2742Y-1.6017
X-0.2957Y-1.5979
X-0.3173Y-1.5937
X-0.3389Y-1.5893
X-0.3605Y-1.5845
X-0.3821Y-1.5794
X-0.4038Y-1.5740
X-0.4255Y-1.5683
X-0.4471Y-1.5623
X-0.4688Y-1.5559
X-0.4904Y-1.5492
X-0.5120Y-1.5422
X-0.5336Y-1.5349
X-0.5552Y-1.5272
X-0.5767Y-1.5192
X-0.5982Y-1.5109
X-0.6196Y-1.5023
X-0.6409Y-1.4933
X-0.6622Y-1.4840
X-0.6833Y-1.4743
X-0.7044Y-1.4644
X-0.7254Y-1.4541
X-0.7464Y-1.4435
X-0.7671Y-1.4325
X-0.7878Y-1.4213
X-0.8084Y-1.4097
X-0.8288Y-1.3978
X-0.8491Y-1.3855
X-0.8692Y-1.3730
X-0.8892Y-1.3601
X-0.9090Y-1.3469
X-0.9287Y-1.3335
X-0.9482Y-1.3197
X-0.9675Y-1.3056
X-0.9866Y-1.2912
X-1.0055Y-1.2765
X-1.0242Y-1.2616
X-1.0427Y-1.2463
X-1.0610Y-1.2308
X-1.0791Y-1.2150
X-1.0969Y-1.1989
X-1.1146Y-1.1825
X-1.1319Y-1.1659
X-1.1490Y-1.1490
X-1.1659Y-1.1319
X-1.1825Y-1.1146
X-1.1989Y-1.0969
X-1.2150Y-1.0791
X-1.2308Y-1.0610
X-1.2463Y-1.0427
X-1.2616Y-1.0242
X-1.2765Y-1.0055
X-1.2912Y-0.9866
X-1.3056Y-0.9675
X-1.3197Y-0.9482
X-1.3335Y-0.9287
X-1.3469Y-0.9090
X-1.3601Y-0.8892
X-1.3730Y-0.8692
X-1.3855Y-0.8491
X-1.3978Y-0.8288
X-1.4097Y-0.8084
X-1.4213Y-0.7878
X-1.4325Y-0.7671
X-1.4435Y-0.7464
X-1.4541Y-0.7254
X-1.4644Y-0.7044
X-1.4743Y-0.6833
X-1.4840Y-0.6622
X-1.4933Y-0.6409
X-1.5023Y-0.6196
X-1.5109Y-0.5982
X-1.5192Y-0.5767
X-1.5272Y-0.5552
X-1.5349Y-0.5336
X-1.5422Y-0.5120
X-1.5492Y-0.4904
X-1.5559Y-0.4688
X-1.5623Y-0.4471
X-1.5683Y-0.4255
X-1.5740Y-0.4038
X-1.5794Y-0.3821
X-1.5845Y-0.3605
X-1.5893Y-0.3389
X-1.5937Y-0.3173
X-1.5979Y-0.2957
X-1.6017Y-0.2742
X-1.6052Y-0.2527
X-1.6085Y-0.2312
X-1.6114Y-0.2098
X-1.6140Y-0.1885
X-1.6164Y-0.1672
X-1.6184Y-0.1460
X-1.6202Y-0.1249
X-1.6217Y-0.1038
X-1.6229Y-0.0829
X-1.6238Y-0.0620
X-1.6245Y-0.0412
X-1.6249Y-0.0206
X-1.6250Y0.0000
X-1.6249Y0.0206
X-1.6245Y0.0412
X-1.6238Y0.0620
X-1.6229Y0.0829
X-1.6217Y0.1038
X-1.6202Y0.1249
X-1.6184Y0.1460
X-1.6164Y0.1672
X-1.6140Y0.1885
X-1.6114Y0.2098
X-1.6085Y0.2312
X-1.6052Y0.2527
X-1.6017Y0.2742
X-1.5979Y0.2957
X-1.5937Y0.3173
X-1.5893Y0.3389
X-1.5845Y0.3605
X-1.5794Y0.3821
X-1.5740Y0.4038
X-1.5683Y0.4255
X-1.5623Y0.4471
X-1.5559Y0.4688
X-1.5492Y0.4904
X-1.5422Y0.5120
X-1.5349Y0.5336
X-1.5272Y0.5552
X-1.5192Y0.5767
X-1.5109Y0.5982
X-1.5023Y0.6196
X-1.4933Y0.6409
X-1.4840Y0.6622
X-1.4743Y0.6833
X-1.4644Y0.7044
X-1.4541Y0.7254
X-1.4435Y0.7464
X-1.4325Y0.7671
X-1.4213Y0.7878
X-1.4097Y0.8084
X-1.3978Y0.8288
X-1.3855Y0.8491
X-1.3730Y0.8692
X-1.3601Y0.8892
X-1.3469Y0.9090
X-1.3335Y0.9287
X-1.3197Y0.9482
X-1.3056Y0.9675
X-1.2912Y0.9866
X-1.2765Y1.0055
X-1.2616Y1.0242
X-1.2463Y1.0427
X-1.2308Y1.0610
X-1.2150Y1.0791
X-1.1989Y1.0969
X-1.1825Y1.1146
X-1.1659Y1.1319
X-1.1490Y1.1490
X-1.1319Y1.1659
X-1.1146Y1.1825
X-1.0969Y1.1989
X-1.0791Y1.2150
X-1.0610Y1.2308
X-1.0427Y1.2463
X-1.0242Y1.2616
X-1.0055Y1.2765
X-0.9866Y1.2912
X-0.9675Y1.3056
X-0.9482Y1.3197
X-0.9287Y1.3335
X-0.9090Y1.3469
X-0.8892Y1.3601
X-0.8692Y1.3730
X-0.8491Y1.3855
X-0.8288Y1.3978
X-0.8084Y1.4097
X-0.7878Y1.4213
X-0.7671Y1.4325
X-0.7464Y1.4435
X-0.7254Y1.4541
X-0.7044Y1.4644
X-0.6833Y1.4743
X-0.6622Y1.4840
X-0.6409Y1.4933
X-0.6196Y1.5023
X-0.5982Y1.5109
X-0.5767Y1.5192
X-0.5552Y1.5272
X-0.5336Y1.5349
X-0.5120Y1.5422
X-0.4904Y1.5492
X-0.4688Y1.5559
X-0.4471Y1.5623
X-0.4255Y1.5683
X-0.4038Y1.5740
X-0.3821Y1.5794
X-0.3605Y1.5845
X-0.3389Y1.5893
X-0.3173Y1.5937
X-0.2957Y1.5979
X-0.2742Y1.6017
X-0.2527Y1.6052
X-0.2312Y1.6085
X-0.2098Y1.6114
X-0.1885Y1.6140
X-0.1672Y1.6164
X-0.1460Y1.6184
X-0.1249Y1.6202
X-0.1038Y1.6217
X-0.0829Y1.6229
X-0.0620Y1.6238
X-0.0412Y1.6245
X-0.0206Y1.6249
X0.0000Y1.6250
G1Z-0.2500F30.0
X0.0412Y1.6245
X0.0620Y1.6238
X0.0829Y1.6229
X0.1038Y1.6217
X0.1249Y1.6202
X0.1460Y1.6184
X0.1672Y1.6164
X0.1885Y1.6140
X0.2098Y1.6114
X0.2312Y1.6085
X0.2527Y1.6052
X0.2742Y1.6017
X0.2957Y1.5979
X0.3173Y1.5937
X0.3389Y1.5893
X0.3605Y1.5845
X0.3821Y1.5794
X0.4038Y1.5740
X0.4255Y1.5683
X0.4471Y1.5623
X0.4688Y1.5559
X0.4904Y1.5492
X0.5120Y1.5422
X0.5336Y1.5349
X0.5552Y1.5272
X0.5767Y1.5192
X0.5982Y1.5109
X0.6196Y1.5023
X0.6409Y1.4933
X0.6622Y1.4840
X0.6833Y1.4743
X0.7044Y1.4644
X0.7254Y1.4541
X0.7464Y1.4435
X0.7671Y1.4325
X0.7878Y1.4213
X0.8084Y1.4097
X0.8288Y1.3978
X0.8491Y1.3855
X0.8692Y1.3730
X0.8892Y1.3601
X0.9090Y1.3469
X0.9287Y1.3335
X0.9482Y1.3197
X0.9675Y1.3056
X0.9866Y1.2912
X1.0055Y1.2765
X1.0242Y1.2616
X1.0427Y1.2463
X1.0610Y1.2308
X1.0791Y1.2150
X1.0969Y1.1989
X1.1146Y1.1825
X1.1319Y1.1659
X1.1490Y1.1490
X1.1659Y1.1319
X1.1825Y1.1146
X1.1989Y1.0969
X1.2150Y1.0791
X1.2308Y1.0610
X1.2463Y1.0427
X1.2616Y1.0242
X1.2765Y1.0055
X1.2912Y0.9866
X1.3056Y0.9675
X1.3197Y0.9482
X1.3335Y0.9287
X1.3469Y0.9090
X1.3601Y0.8892
X1.3730Y0.8692
X1.3855Y0.8491
X1.3978Y0.8288
X1.4097Y0.8084
X1.4213Y0.7878
X1.4325Y0.7671
X1.4435Y0.7464
X1.4541Y0.7254
X1.4644Y0.7044
X1.4743Y0.6833
X1.4840Y0.6622
X1.4933Y0.6409
X1.5023Y0.6196
X1.5109Y0.5982
X1.5192Y0.5767
X1.5272Y0.5552
X1.5349Y0.5336
X1.5422Y0.5120
X1.5492Y0.4904
X1.5559Y0.4688
X1.5623Y0.4471
X1.5683Y0.4255
X1.5740Y0.4038
X1.5794Y0.3821
X1.5845Y0.3605
X1.5893Y0.3389
X1.5937Y0.3173
X1.5979Y0.2957
X1.6017Y0.2742
X1.6052Y0.2527
X1.6085Y0.2312
X1.6114Y0.2098
X1.6140Y0.1885
X1.6164Y0.1672
X1.6184Y0.1460
X1.6202Y0.1249
X1.6217Y0.1038
X1.6229Y0.0829
X1.6238Y0.0620
X1.6245Y0.0412
X1.6249Y0.0206
X1.6250Y0.0000
X1.6249Y-0.0206
X1.6245Y-0.0412
X1.6238Y-0.0620
X1.6229Y-0.0829
X1.6217Y-0.1038
X1.6202Y-0.1249
X1.6184Y-0.1460
X1.6164Y-0.1672
X1.6140Y-0.1885
X1.6114Y-0.2098
X1.6085Y-0.2312
X1.6052Y-0.2527
X1.6017Y-0.2742
X1.5979Y-0.2957
X1.5937Y-0.3173
X1.5893Y-0.3389
X1.5845Y-0.3605
X1.5794Y-0.3821
X1.5740Y-0.4038
X1.5683Y-0.4255
X1.5623Y-0.4471
X1.5559Y-0.4688
X1.5492Y-0.4904
X1.5422Y-0.5120
X1.5349Y-0.5336
X1.5272Y-0.5552
X1.5192Y-0.5767
X1.5109Y-0.5982
X1.5023Y-0.6196
X1.4933Y-0.6409
X1.4840Y-0.6622
X1.4743Y-0.6833
X1.4644Y-0.7044
X1.4541Y-0.7254
X1.4435Y-0.7464
X1.4325Y-0.7671
X1.4213Y-0.7878
X1.4097Y-0.8084
X1.3978Y-0.8288
X1.3855Y-0.8491
X1.3730Y-0.8692
X1.3601Y-0.8892
X1.3469Y-0.9090
X1.3335Y-0.9287
X1.3197Y-0.9482
X1.3056Y-0.9675
X1.2912Y-0.9866
X1.2765Y-1.0055
X1.2616Y-1.0242
X1.2463Y-1.0427
X1.2308Y-1.0610
X1.2150Y-1.0791
X1.1989Y-1.0969
X1.1825Y-1.1146
X1.1659Y-1.1319
X1.1490Y-1.1490
X1.1319Y-1.1659
X1.1146Y-1.1825
X1.0969Y-1.1989
X1.0791Y-1.2150
X1.0610Y-1.2308
X1.0427Y-1.2463
X1.0242Y-1.2616
X1.0055Y-1.2765
X0.9866Y-1.2912
X0.9675Y-1.3056
X0.9482Y-1.3197
X0.9287Y-1.3335
X0.9090Y-1.3469
X0.8892Y-1.3601
X0.8692Y-1.3730
X0.8491Y-1.3855
X0.8288Y-1.3978
X0.8084Y-1.4097
X0.7878Y-1.4213
X0.7671Y-1.4325
X0.7464Y-1.4435
X0.7254Y-1.4541
X0.7044Y-1.4644
X0.6833Y-1.4743
X0.6622Y-1.4840
X0.6409Y-1.4933
X0.6196Y-1.5023
X0.5982Y-1.5109
X0.5767Y-1.5192
X0.5552Y-1.5272
X0.5336Y-1.5349
X0.5120Y-1.5422
X0.4904Y-1.5492
X0.4688Y-1.5559
X0.4471Y-1.5623
X0.4255Y-1.5683
X0.4038Y-1.5740
X0.3821Y-1.5794
X0.3605Y-1.5845
X0.3389Y-1.5893
X0.3173Y-1.5937
X0.2957Y-1.5979
X0.2742Y-1.6017
X0.2527Y-1.6052
X0.2312Y-1.6085
X0.2098Y-1.6114
X0.1885Y-1.6140
X0.1672Y-1.6164
X0.1460Y-1.6184
X0.1249Y-1.6202
X0.1038Y-1.6217
X0.0829Y-1.6229
X0.0620Y-1.6238
X0.0412Y-1.6245
X0.0206Y-1.6249
X0.0000Y-1.6250
X-0.0206Y-1.6249
X-0.0412Y-1.6245
X-0.0620Y-1.6238
X-0.0829Y-1.6229
X-0.1038Y-1.6217
X-0.1249Y-1.6202
X-0.1460Y-1.6184
X-0.1672Y-1.6164
X-0.1885Y-1.6140
X-0.2098Y-1.6114
X-0.2312Y-1.6085
X-0.2527Y-1.6052
X-0.2742Y-1.6017
X-0.2957Y-1.5979
X-0.3173Y-1.5937
X-0.3389Y-1.5893
X-0.3605Y-1.5845
X-0.3821Y-1.5794
X-0.4038Y-1.5740
X-0.4255Y-1.5683
X-0.4471Y-1.5623
X-0.4688Y-1.5559
X-0.4904Y-1.5492
X-0.5120Y-1.5422
X-0.5336Y-1.5349
X-0.5552Y-1.5272
X-0.5767Y-1.5192
X-0.5982Y-1.5109
X-0.6196Y-1.5023
X-0.6409Y-1.4933
X-0.6622Y-1.4840
X-0.6833Y-1.4743
X-0.7044Y-1.4644
X-0.7254Y-1.4541
X-0.7464Y-1.4435
X-0.7671Y-1.4325
X-0.7878Y-1.4213
X-0.8084Y-1.4097
X-0.8288Y-1.3978
X-0.8491Y-1.3855
X-0.8692Y-1.3730
X-0.8892Y-1.3601
X-0.9090Y-1.3469
X-0.9287Y-1.3335
X-0.9482Y-1.3197
X-0.9675Y-1.3056
X-0.9866Y-1.2912
X-1.0055Y-1.2765
X-1.0242Y-1.2616
X-1.0427Y-1.2463
X-1.0610Y-1.2308
X-1.0791Y-1.2150
X-1.0969Y-1.1989
X-1.1146Y-1.1825
X-1.1319Y-1.1659
X-1.1490Y-1.1490
X-1.1659Y-1.1319
X-1.1825Y-1.1146
X-1.1989Y-1.0969
X-1.2150Y-1.0791
X-1.2308Y-1.0610
X-1.2463Y-1.0427
X-1.2616Y-1.0242
X-1.2765Y-1.0055
X-1.2912Y-0.9866
X-1.3056Y-0.9675
X-1.3197Y-0.9482
X-1.3335Y-0.9287
X-1.3469Y-0.9090
X-1.3601Y-0.8892
X-1.3730Y-0.8692
X-1.3855Y-0.8491
X-1.3978Y-0.8288
X-1.4097Y-0.8084
X-1.4213Y-0.7878
X-1.4325Y-0.7671
X-1.4435Y-0.7464
X-1.4541Y-0.7254
X-1.4644Y-0.7044
X-1.4743Y-0.6833
X-1.4840Y-0.6622
X-1.4933Y-0.6409
X-1.5023Y-0.6196
X-1.5109Y-0.5982
X-1.5192Y-0.5767
X-1.5272Y-0.5552
X-1.5349Y-0.5336
X-1.5422Y-0.5120
X-1.5492Y-0.4904
X-1.5559Y-0.4688
X-1.5623Y-0.4471
X-1.5683Y-0.4255
X-1.5740Y-0.4038
X-1.5794Y-0.3821
X-1.5845Y-0.3605
X-1.5893Y-0.3389
X-1.5937Y-0.3173
X-1.5979Y-0.2957
X-1.6017Y-0.2742
X-1.6052Y-0.2527
X-1.6085Y-0.2312
X-1.6114Y-0.2098
X-1.6140Y-0.1885
X-1.6164Y-0.1672
X-1.6184Y-0.1460
X-1.6202Y-0.1249
X-1.6217Y-0.1038
X-1.6229Y-0.0829
X-1.6238Y-0.0620
X-1.6245Y-0.0412
X-1.6249Y-0.0206
X-1.6250Y0.0000
X-1.6249Y0.0206
X-1.6245Y0.0412
X-1.6238Y0.0620
X-1.6229Y0.0829
X-1.6217Y0.1038
X-1.6202Y0.1249
X-1.6184Y0.1460
X-1.6164Y0.1672
X-1.6140Y0.1885
X-1.6114Y0.2098
X-1.6085Y0.2312
X-1.6052Y0.2527
X-1.6017Y0.2742
X-1.5979Y0.2957
X-1.5937Y0.3173
X-1.5893Y0.3389
X-1.5845Y0.3605
X-1.5794Y0.3821
X-1.5740Y0.4038
X-1.5683Y0.4255
X-1.5623Y0.4471
X-1.5559Y0.4688
X-1.5492Y0.4904
X-1.5422Y0.5120
X-1.5349Y0.5336
X-1.5272Y0.5552
X-1.5192Y0.5767
X-1.5109Y0.5982
X-1.5023Y0.6196
X-1.4933Y0.6409
X-1.4840Y0.6622
X-1.4743Y0.6833
X-1.4644Y0.7044
X-1.4541Y0.7254
X-1.4435Y0.7464
X-1.4325Y0.7671
X-1.4213Y0.7878
X-1.4097Y0.8084
X-1.3978Y0.8288
X-1.3855Y0.8491
X-1.3730Y0.8692
X-1.3601Y0.8892
X-1.3469Y0.9090
X-1.3335Y0.9287
X-1.3197Y0.9482
X-1.3056Y0.9675
X-1.2912Y0.9866
X-1.2765Y1.0055
X-1.2616Y1.0242
X-1.2463Y1.0427
X-1.2308Y1.0610
X-1.2150Y1.0791
X-1.1989Y1.0969
X-1.1825Y1.1146
X-1.1659Y1.1319
X-1.1490Y1.1490
X-1.1319Y1.1659
X-1.1146Y1.1825
X-1.0969Y1.1989
X-1.0791Y1.2150
X-1.0610Y1.2308
X-1.0427Y1.2463
X-1.0242Y1.2616
X-1.0055Y1.2765
X-0.9866Y1.2912
X-0.9675Y1.3056
X-0.9482Y1.3197
X-0.9287Y1.3335
X-0.9090Y1.3469
X-0.8892Y1.3601
X-0.8692Y1.3730
X-0.8491Y1.3855
X-0.8288Y1.3978
X-0.8084Y1.4097
X-0.7878Y1.4213
X-0.7671Y1.4325
X-0.7464Y1.4435
X-0.7254Y1.4541
X-0.7044Y1.4644
X-0.6833Y1.4743
X-0.6622Y1.4840
X-0.6409Y1.4933
X-0.6196Y1.5023
X-0.5982Y1.5109
X-0.5767Y1.5192
X-0.5552Y1.5272
X-0.5336Y1.5349
X-0.5120Y1.5422
X-0.4904Y1.5492
X-0.4688Y1.5559
X-0.4471Y1.5623
X-0.4255Y1.5683
X-0.4038Y1.5740
X-0.3821Y1.5794
X-0.3605Y1.5845
X-0.3389Y1.5893
X-0.3173Y1.5937
X-0.2957Y1.5979
X-0.2742Y1.6017
X-0.2527Y1.6052
X-0.2312Y1.6085
X-0.2098Y1.6114
X-0.1885Y1.6140
X-0.1672Y1.6164
X-0.1460Y1.6184
X-0.1249Y1.6202
X-0.1038Y1.6217
X-0.0829Y1.6229
X-0.0620Y1.6238
X-0.0412Y1.6245
X-0.0206Y1.6249
X0.0000Y1.6250
G1Z-0.3750F30.0
X0.0412Y1.6245
X0.0620Y1.6238
X0.0829Y1.6229
X0.1038Y1.6217
X0.1249Y1.6202
X0.1460Y1.6184
X0.1672Y1.6164
X0.1885Y1.6140
X0.2098Y1.6114
X0.2312Y1.6085
X0.2527Y1.6052
X0.2742Y1.6017
X0.2957Y1.5979
X0.3173Y1.5937
X0.3389Y1.5893
X0.3605Y1.5845
X0.3821Y1.5794
X0.4038Y1.5740
X0.4255Y1.5683
X0.4471Y1.5623
X0.4688Y1.5559
X0.4904Y1.5492
X0.5120Y1.5422
X0.5336Y1.5349
X0.5552Y1.5272
X0.5767Y1.5192
X0.5982Y1.5109
X0.6196Y1.5023
X0.6409Y1.4933
X0.6622Y1.4840
X0.6833Y1.4743
X0.7044Y1.4644
X0.7254Y1.4541
X0.7464Y1.4435
X0.7671Y1.4325
X0.7878Y1.4213
X0.8084Y1.4097
X0.8288Y1.3978
X0.8491Y1.3855
X0.8692Y1.3730
X0.8892Y1.3601
X0.9090Y1.3469
X0.9287Y1.3335
X0.9482Y1.3197
X0.9675Y1.3056
X0.9866Y1.2912
X1.0055Y1.2765
X1.0242Y1.2616
X1.0427Y1.2463
X1.0610Y1.2308
X1.0791Y1.2150
X1.0969Y1.1989
X1.1146Y1.1825
X1.1319Y1.1659
X1.1490Y1.1490
X1.1659Y1.1319
X1.1825Y1.1146
X1.1989Y1.0969
X1.2150Y1.0791
X1.2308Y1.0610
X1.2463Y1.0427
X1.2616Y1.0242
X1.2765Y1.0055
X1.2912Y0.9866
X1.3056Y0.9675
X1.3197Y0.9482
X1.3335Y0.9287
X1.3469Y0.9090
X1.3601Y0.8892
X1.3730Y0.8692
X1.3855Y0.8491
X1.3978Y0.8288
X1.4097Y0.8084
X1.4213Y0.7878
X1.4325Y0.7671
X1.4435Y0.7464
X1.4541Y0.7254
X1.4644Y0.7044
X1.4743Y0.6833
X1.4840Y0.6622
X1.4933Y0.6409
X1.5023Y0.6196
X1.5109Y0.5982
X1.5192Y0.5767
X1.5272Y0.5552
X1.5349Y0.5336
X1.5422Y0.5120
X1.5492Y0.4904
X1.5559Y0.4688
X1.5623Y0.4471
X1.5683Y0.4255
X1.5740Y0.4038
X1.5794Y0.3821
X1.5845Y0.3605
X1.5893Y0.3389
X1.5937Y0.3173
X1.5979Y0.2957
X1.6017Y0.2742
X1.6052Y0.2527
X1.6085Y0.2312
X1.6114Y0.2098
X1.6140Y0.1885
X1.6164Y0.1672
X1.6184Y0.1460
X1.6202Y0.1249
X1.6217Y0.1038
X1.6229Y0.0829
X1.6238Y0.0620
X1.6245Y0.0412
X1.6249Y0.0206
X1.6250Y0.0000
X1.6249Y-0.0206
X1.6245Y-0.0412
X1.6238Y-0.0620
X1.6229Y-0.0829
X1.6217Y-0.1038
X1.6202Y-0.1249
X1.6184Y-0.1460
X1.6164Y-0.1672
X1.6140Y-0.1885
X1.6114Y-0.2098
X1.6085Y-0.2312
X1.6052Y-0.2527
X1.6017Y-0.2742
X1.5979Y-0.2957
X1.5937Y-0.3173
X1.5893Y-0.3389
X1.5845Y-0.3605
X1.5794Y-0.3821
X1.5740Y-0.4038
X1.5683Y-0.4255
X1.5623Y-0.4471
X1.5559Y-0.4688
X1.5492Y-0.4904
X1.5422Y-0.5120
X1.5349Y-0.5336
X1.5272Y-0.5552
X1.5192Y-0.5767
X1.5109Y-0.5982
X1.5023Y-0.6196
X1.4933Y-0.6409
X1.4840Y-0.6622
X1.4743Y-0.6833
X1.4644Y-0.7044
X1.4541Y-0.7254
X1.4435Y-0.7464
X1.4325Y-0.7671
X1.4213Y-0.7878
X1.4097Y-0.8084
X1.3978Y-0.8288
X1.3855Y-0.8491
X1.3730Y-0.8692
X1.3601Y-0.8892
X1.3469Y-0.9090
X1.3335Y-0.9287
X1.3197Y-0.9482
X1.3056Y-0.9675
X1.2912Y-0.9866
X1.2765Y-1.0055
X1.2616Y-1.0242
X1.2463Y-1.0427
X1.2308Y-1.0610
X1.2150Y-1.0791
X1.1989Y-1.0969
X1.1825Y-1.1146
X1.1659Y-1.1319
X1.1490Y-1.1490
X1.1319Y-1.1659
X1.1146Y-1.1825
X1.0969Y-1.1989
X1.0791Y-1.2150
X1.0610Y-1.2308
X1.0427Y-1.2463
X1.0242Y-1.2616
X1.0055Y-1.2765
X0.9866Y-1.2912
X0.9675Y-1.3056
X0.9482Y-1.3197
X0.9287Y-1.3335
X0.9090Y-1.3469
X0.8892Y-1.3601
X0.8692Y-1.3730
X0.8491Y-1.3855
X0.8288Y-1.3978
X0.8084Y-1.4097
X0.7878Y-1.4213
X0.7671Y-1.4325
X0.7464Y-1.4435
X0.7254Y-1.4541
X0.7044Y-1.4644
X0.6833Y-1.4743
X0.6622Y-1.4840
X0.6409Y-1.4933
X0.6196Y-1.5023
X0.5982Y-1.5109
X0.5767Y-1.5192
X0.5552Y-1.5272
X0.5336Y-1.5349
X0.5120Y-1.5422
X0.4904Y-1.5492
X0.4688Y-1.5559
X0.4471Y-1.5623
X0.4255Y-1.5683
X0.4038Y-1.5740
X0.3821Y-1.5794
X0.3605Y-1.5845
X0.3389Y-1.5893
X0.3173Y-1.5937
X0.2957Y-1.5979
X0.2742Y-1.6017
X0.2527Y-1.6052
X0.2312Y-1.6085
X0.2098Y-1.6114
X0.1885Y-1.6140
X0.1672Y-1.6164
X0.1460Y-1.6184
X0.1249Y-1.6202
X0.1038Y-1.6217
X0.0829Y-1.6229
X0.0620Y-1.6238
X0.0412Y-1.6245
X0.0206Y-1.6249
X0.0000Y-1.6250
X-0.0206Y-1.6249
X-0.0412Y-1.6245
X-0.0620Y-1.6238
X-0.0829Y-1.6229
X-0.1038Y-1.6217
X-0.1249Y-1.6202
X-0.1460Y-1.6184
X-0.1672Y-1.6164
X-0.1885Y-1.6140
X-0.2098Y-1.6114
X-0.2312Y-1.6085
X-0.2527Y-1.6052
X-0.2742Y-1.6017
X-0.2957Y-1.5979
X-0.3173Y-1.5937
X-0.3389Y-1.5893
X-0.3605Y-1.5845
X-0.3821Y-1.5794
X-0.4038Y-1.5740
X-0.4255Y-1.5683
X-0.4471Y-1.5623
X-0.4688Y-1.5559
X-0.4904Y-1.5492
X-0.5120Y-1.5422
X-0.5336Y-1.5349
X-0.5552Y-1.5272
X-0.5767Y-1.5192
X-0.5982Y-1.5109
X-0.6196Y-1.5023
X-0.6409Y-1.4933
X-0.6622Y-1.4840
X-0.6833Y-1.4743
X-0.7044Y-1.4644
X-0.7254Y-1.4541
X-0.7464Y-1.4435
X-0.7671Y-1.4325
X-0.7878Y-1.4213
X-0.8084Y-1.4097
X-0.8288Y-1.3978
X-0.8491Y-1.3855
X-0.8692Y-1.3730
X-0.8892Y-1.3601
X-0.9090Y-1.3469
X-0.9287Y-1.3335
X-0.9482Y-1.3197
X-0.9675Y-1.3056
X-0.9866Y-1.2912
X-1.0055Y-1.2765
X-1.0242Y-1.2616
X-1.0427Y-1.2463
X-1.0610Y-1.2308
X-1.0791Y-1.2150
X-1.0969Y-1.1989
X-1.1146Y-1.1825
X-1.1319Y-1.1659
X-1.1490Y-1.1490
X-1.1659Y-1.1319
X-1.1825Y-1.1146
X-1.1989Y-1.0969
X-1.2150Y-1.0791
X-1.2308Y-1.0610
X-1.2463Y-1.0427
X-1.2616Y-1.0242
X-1.2765Y-1.0055
X-1.2912Y-0.9866
X-1.3056Y-0.9675
X-1.3197Y-0.9482
X-1.3335Y-0.9287
X-1.3469Y-0.9090
X-1.3601Y-0.8892
X-1.3730Y-0.8692
X-1.3855Y-0.8491
X-1.3978Y-0.8288
X-1.4097Y-0.8084
X-1.4213Y-0.7878
X-1.4325Y-0.7671
X-1.4435Y-0.7464
X-1.4541Y-0.7254
X-1.4644Y-0.7044
X-1.4743Y-0.6833
X-1.4840Y-0.6622
X-1.4933Y-0.6409
X-1.5023Y-0.6196
X-1.5109Y-0.5982
X-1.5192Y-0.5767
X-1.5272Y-0.5552
X-1.5349Y-0.5336
X-1.5422Y-0.5120
X-1.5492Y-0.4904
X-1.5559Y-0.4688
X-1.5623Y-0.4471
X-1.5683Y-0.4255
X-1.5740Y-0.4038
X-1.5794Y-0.3821
X-1.5845Y-0.3605
X-1.5893Y-0.3389
X-1.5937Y-0.3173
X-1.5979Y-0.2957
X-1.6017Y-0.2742
X-1.6052Y-0.2527
X-1.6085Y-0.2312
X-1.6114Y-0.2098
X-1.6140Y-0.1885
X-1.6164Y-0.1672
X-1.6184Y-0.1460
X-1.6202Y-0.1249
X-1.6217Y-0.1038
X-1.6229Y-0.0829
X-1.6238Y-0.0620
X-1.6245Y-0.0412
X-1.6249Y-0.0206
X-1.6250Y0.0000
X-1.6249Y0.0206
X-1.6245Y0.0412
X-1.6238Y0.0620
X-1.6229Y0.0829
X-1.6217Y0.1038
X-1.6202Y0.1249
X-1.6184Y0.1460
X-1.6164Y0.1672
X-1.6140Y0.1885
X-1.6114Y0.2098
X-1.6085Y0.2312
X-1.6052Y0.2527
X-1.6017Y0.2742
X-1.5979Y0.2957
X-1.5937Y0.3173
X-1.5893Y0.3389
X-1.5845Y0.3605
X-1.5794Y0.3821
X-1.5740Y0.4038
X-1.5683Y0.4255
X-1.5623Y0.4471
X-1.5559Y0.4688
X-1.5492Y0.4904
X-1.5422Y0.5120
X-1.5349Y0.5336
X-1.5272Y0.5552
X-1.5192Y0.5767
X-1.5109Y0.5982
X-1.5023Y0.6196
X-1.4933Y0.6409
X-1.4840Y0.6622
X-1.4743Y0.6833
X-1.4644Y0.7044
X-1.4541Y0.7254
X-1.4435Y0.7464
X-1.4325Y0.7671
X-1.4213Y0.7878
X-1.4097Y0.8084
X-1.3978Y0.8288
X-1.3855Y0.8491
X-1.3730Y0.8692
X-1.3601Y0.8892
X-1.3469Y0.9090
X-1.3335Y0.9287
X-1.3197Y0.9482
X-1.3056Y0.9675
X-1.2912Y0.9866
X-1.2765Y1.0055
X-1.2616Y1.0242
X-1.2463Y1.0427
X-1.2308Y1.0610
X-1.2150Y1.0791
X-1.1989Y1.0969
X-1.1825Y1.1146
X-1.1659Y1.1319
X-1.1490Y1.1490
X-1.1319Y1.1659
X-1.1146Y1.1825
X-1.0969Y1.1989
X-1.0791Y1.2150
X-1.0610Y1.2308
X-1.0427Y1.2463
X-1.0242Y1.2616
X-1.0055Y1.2765
X-0.9866Y1.2912
X-0.9675Y1.3056
X-0.9482Y1.3197
X-0.9287Y1.3335
X-0.9090Y1.3469
X-0.8892Y1.3601
X-0.8692Y1.3730
X-0.8491Y1.3855
X-0.8288Y1.3978
X-0.8084Y1.4097
X-0.7878Y1.4213
X-0.7671Y1.4325
X-0.7464Y1.4435
X-0.7254Y1.4541
X-0.7044Y1.4644
X-0.6833Y1.4743
X-0.6622Y1.4840
X-0.6409Y1.4933
X-0.6196Y1.5023
X-0.5982Y1.5109
X-0.5767Y1.5192
X-0.5552Y1.5272
X-0.5336Y1.5349
X-0.5120Y1.5422
X-0.4904Y1.5492
X-0.4688Y1.5559
X-0.4471Y1.5623
X-0.4255Y1.5683
X-0.4038Y1.5740
X-0.3821Y1.5794
X-0.3605Y1.5845
X-0.3389Y1.5893
X-0.3173Y1.5937
X-0.2957Y1.5979
X-0.2742Y1.6017
X-0.2527Y1.6052
X-0.2312Y1.6085
X-0.2098Y1.6114
X-0.1885Y1.6140
X-0.1672Y1.6164
X-0.1460Y1.6184
X-0.1249Y1.6202
X-0.1038Y1.6217
X-0.0829Y1.6229
X-0.0620Y1.6238
X-0.0412Y1.6245
X-0.0206Y1.6249
X0.0000Y1.6250
G1Z-0.5000F30.0
X0.0412Y1.6245
X0.0620Y1.6238
X0.0829Y1.6229
X0.1038Y1.6217
X0.1249Y1.6202
X0.1460Y1.6184
X0.1672Y1.6164
X0.1885Y1.6140
X0.2098Y1.6114
X0.2312Y1.6085
X0.2527Y1.6052
X0.2742Y1.6017
X0.2957Y1.5979
X0.3173Y1.5937
X0.3389Y1.5893
X0.3605Y1.5845
X0.3821Y1.5794
X0.4038Y1.5740
X0.4255Y1.5683
X0.4471Y1.5623
X0.4688Y1.5559
X0.4904Y1.5492
X0.5120Y1.5422
X0.5336Y1.5349
X0.5552Y1.5272
X0.5767Y1.5192
X0.5982Y1.5109
X0.6196Y1.5023
X0.6409Y1.4933
X0.6622Y1.4840
X0.6833Y1.4743
X0.7044Y1.4644
X0.7254Y1.4541
X0.7464Y1.4435
X0.7671Y1.4325
X0.7878Y1.4213
X0.8084Y1.4097
X0.8288Y1.3978
X0.8491Y1.3855
X0.8692Y1.3730
X0.8892Y1.3601
X0.9090Y1.3469
X0.9287Y1.3335
X0.9482Y1.3197
X0.9675Y1.3056
X0.9866Y1.2912
X1.0055Y1.2765
X1.0242Y1.2616
X1.0427Y1.2463
X1.0610Y1.2308
X1.0791Y1.2150
X1.0969Y1.1989
X1.1146Y1.1825
X1.1319Y1.1659
X1.1490Y1.1490
X1.1659Y1.1319
X1.1825Y1.1146
X1.1989Y1.0969
X1.2150Y1.0791
X1.2308Y1.0610
X1.2463Y1.0427
X1.2616Y1.0242
X1.2765Y1.0055
X1.2912Y0.9866
X1.3056Y0.9675
X1.3197Y0.9482
X1.3335Y0.9287
X1.3469Y0.9090
X1.3601Y0.8892
X1.3730Y0.8692
X1.3855Y0.8491
X1.3978Y0.8288
X1.4097Y0.8084
X1.4213Y0.7878
X1.4325Y0.7671
X1.4435Y0.7464
X1.4541Y0.7254
X1.4644Y0.7044
X1.4743Y0.6833
X1.4840Y0.6622
X1.4933Y0.6409
X1.5023Y0.6196
X1.5109Y0.5982
X1.5192Y0.5767
X1.5272Y0.5552
X1.5349Y0.5336
X1.5422Y0.5120
X1.5492Y0.4904
X1.5559Y0.4688
X1.5623Y0.4471
X1.5683Y0.4255
X1.5740Y0.4038
X1.5794Y0.3821
X1.5845Y0.3605
X1.5893Y0.3389
X1.5937Y0.3173
X1.5979Y0.2957
X1.6017Y0.2742
X1.6052Y0.2527
X1.6085Y0.2312
X1.6114Y0.2098
X1.6140Y0.1885
X1.6164Y0.1672
X1.6184Y0.1460
X1.6202Y0.1249
X1.6217Y0.1038
X1.6229Y0.0829
X1.6238Y0.0620
X1.6245Y0.0412
X1.6249Y0.0206
X1.6250Y0.0000
X1.6249Y-0.0206
X1.6245Y-0.0412
X1.6238Y-0.0620
X1.6229Y-0.0829
X1.6217Y-0.1038
X1.6202Y-0.1249
X1.6184Y-0.1460
X1.6164Y-0.1672
X1.6140Y-0.1885
X1.6114Y-0.2098
X1.6085Y-0.2312
X1.6052Y-0.2527
X1.6017Y-0.2742
X1.5979Y-0.2957
X1.5937Y-0.3173
X1.5893Y-0.3389
X1.5845Y-0.3605
X1.5794Y-0.3821
X1.5740Y-0.4038
X1.5683Y-0.4255
X1.5623Y-0.4471
X1.5559Y-0.4688
X1.5492Y-0.4904
X1.5422Y-0.5120
X1.5349Y-0.5336
X1.5272Y-0.5552
X1.5192Y-0.5767
X1.5109Y-0.5982
X1.5023Y-0.6196
X1.4933Y-0.6409
X1.4840Y-0.6622
X1.4743Y-0.6833
X1.4644Y-0.7044
X1.4541Y-0.7254
X1.4435Y-0.7464
X1.4325Y-0.7671
X1.4213Y-0.7878
X1.4097Y-0.8084
X1.3978Y-0.8288
X1.3855Y-0.8491
X1.3730Y-0.8692
X1.3601Y-0.8892
X1.3469Y-0.9090
X1.3335Y-0.9287
X1.3197Y-0.9482
X1.3056Y-0.9675
X1.2912Y-0.9866
X1.2765Y-1.0055
X1.2616Y-1.0242
X1.2463Y-1.0427
X1.2308Y-1.0610
X1.2150Y-1.0791
X1.1989Y-1.0969
X1.1825Y-1.1146
X1.1659Y-1.1319
X1.1490Y-1.1490
X1.1319Y-1.1659
X1.1146Y-1.1825
X1.0969Y-1.1989
X1.0791Y-1.2150
X1.0610Y-1.2308
X1.0427Y-1.2463
X1.0242Y-1.2616
X1.0055Y-1.2765
X0.9866Y-1.2912
X0.9675Y-1.3056
X0.9482Y-1.3197
X0.9287Y-1.3335
X0.9090Y-1.3469
X0.8892Y-1.3601
X0.8692Y-1.3730
X0.8491Y-1.3855
X0.8288Y-1.3978
X0.8084Y-1.4097
X0.7878Y-1.4213
X0.7671Y-1.4325
X0.7464Y-1.4435
X0.7254Y-1.4541
X0.7044Y-1.4644
X0.6833Y-1.4743
X0.6622Y-1.4840
X0.6409Y-1.4933
X0.6196Y-1.5023
X0.5982Y-1.5109
X0.5767Y-1.5192
X0.5552Y-1.5272
X0.5336Y-1.5349
X0.5120Y-1.5422
X0.4904Y-1.5492
X0.4688Y-1.5559
X0.4471Y-1.5623
X0.4255Y-1.5683
X0.4038Y-1.5740
X0.3821Y-1.5794
X0.3605Y-1.5845
X0.3389Y-1.5893
X0.3173Y-1.5937
X0.2957Y-1.5979
X0.2742Y-1.6017
X0.2527Y-1.6052
X0.2312Y-1.6085
X0.2098Y-1.6114
X0.1885Y-1.6140
X0.1672Y-1.6164
X0.1460Y-1.6184
X0.1249Y-1.6202
X0.1038Y-1.6217
X0.0829Y-1.6229
X0.0620Y-1.6238
X0.0412Y-1.6245
X0.0206Y-1.6249
X0.0000Y-1.6250
X-0.0206Y-1.6249
X-0.0412Y-1.6245
X-0.0620Y-1.6238
X-0.0829Y-1.6229
X-0.1038Y-1.6217
X-0.1249Y-1.6202
X-0.1460Y-1.6184
X-0.1672Y-1.6164
X-0.1885Y-1.6140
X-0.2098Y-1.6114
X-0.2312Y-1.6085
X-0.2527Y-1.6052
X-0.2742Y-1.6017
X-0.2957Y-1.5979
X-0.3173Y-1.5937
X-0.3389Y-1.5893
X-0.3605Y-1.5845
X-0.3821Y-1.5794
X-0.4038Y-1.5740
X-0.4255Y-1.5683
X-0.4471Y-1.5623
X-0.4688Y-1.5559
X-0.4904Y-1.5492
X-0.5120Y-1.5422
X-0.5336Y-1.5349
X-0.5552Y-1.5272
X-0.5767Y-1.5192
X-0.5982Y-1.5109
X-0.6196Y-1.5023
X-0.6409Y-1.4933
X-0.6622Y-1.4840
X-0.6833Y-1.4743
X-0.7044Y-1.4644
X-0.7254Y-1.4541
X-0.7464Y-1.4435
X-0.7671Y-1.4325
X-0.7878Y-1.4213
X-0.8084Y-1.4097
X-0.8288Y-1.3978
X-0.8491Y-1.3855
X-0.8692Y-1.3730
X-0.8892Y-1.3601
X-0.9090Y-1.3469
X-0.9287Y-1.3335
X-0.9482Y-1.3197
X-0.9675Y-1.3056
X-0.9866Y-1.2912
X-1.0055Y-1.2765
X-1.0242Y-1.2616
X-1.0427Y-1.2463
X-1.0610Y-1.2308
X-1.0791Y-1.2150
X-1.0969Y-1.1989
X-1.1146Y-1.1825
X-1.1319Y-1.1659
X-1.1490Y-1.1490
X-1.1659Y-1.1319
X-1.1825Y-1.1146
X-1.1989Y-1.0969
X-1.2150Y-1.0791
X-1.2308Y-1.0610
X-1.2463Y-1.0427
X-1.2616Y-1.0242
X-1.2765Y-1.0055
X-1.2912Y-0.9866
X-1.3056Y-0.9675
X-1.3197Y-0.9482
X-1.3335Y-0.9287
X-1.3469Y-0.9090
X-1.3601Y-0.8892
X-1.3730Y-0.8692
X-1.3855Y-0.8491
X-1.3978Y-0.8288
X-1.4097Y-0.8084
X-1.4213Y-0.7878
X-1.4325Y-0.7671
X-1.4435Y-0.7464
X-1.4541Y-0.7254
X-1.4644Y-0.7044
X-1.4743Y-0.6833
X-1.4840Y-0.6622
X-1.4933Y-0.6409
X-1.5023Y-0.6196
X-1.5109Y-0.5982
X-1.5192Y-0.5767
X-1.5272Y-0.5552
X-1.5349Y-0.5336
X-1.5422Y-0.5120
X-1.5492Y-0.4904
X-1.5559Y-0.4688
X-1.5623Y-0.4471
X-1.5683Y-0.4255
X-1.5740Y-0.4038
X-1.5794Y-0.3821
X-1.5845Y-0.3605
X-1.5893Y-0.3389
X-1.5937Y-0.3173
X-1.5979Y-0.2957
X-1.6017Y-0.2742
X-1.6052Y-0.2527
X-1.6085Y-0.2312
X-1.6114Y-0.2098
X-1.6140Y-0.1885
X-1.6164Y-0.1672
X-1.6184Y-0.1460
X-1.6202Y-0.1249
X-1.6217Y-0.1038
X-1.6229Y-0.0829
X-1.6238Y-0.0620
X-1.6245Y-0.0412
X-1.6249Y-0.0206
X-1.6250Y0.0000
X-1.6249Y0.0206
X-1.6245Y0.0412
X-1.6238Y0.0620
X-1.6229Y0.0829
X-1.6217Y0.1038
X-1.6202Y0.1249
X-1.6184Y0.1460
X-1.6164Y0.1672
X-1.6140Y0.1885
X-1.6114Y0.2098
X-1.6085Y0.2312
X-1.6052Y0.2527
X-1.6017Y0.2742
X-1.5979Y0.2957
X-1.5937Y0.3173
X-1.5893Y0.3389
X-1.5845Y0.3605
X-1.5794Y0.3821
X-1.5740Y0.4038
X-1.5683Y0.4255
X-1.5623Y0.4471
X-1.5559Y0.4688
X-1.5492Y0.4904
X-1.5422Y0.5120
X-1.5349Y0.5336
X-1.5272Y0.5552
X-1.5192Y0.5767
X-1.5109Y0.5982
X-1.5023Y0.6196
X-1.4933Y0.6409
X-1.4840Y0.6622
X-1.4743Y0.6833
X-1.4644Y0.7044
X-1.4541Y0.7254
X-1.4435Y0.7464
X-1.4325Y0.7671
X-1.4213Y0.7878
X-1.4097Y0.8084
X-1.3978Y0.8288
X-1.3855Y0.8491
X-1.3730Y0.8692
X-1.3601Y0.8892
X-1.3469Y0.9090
X-1.3335Y0.9287
X-1.3197Y0.9482
X-1.3056Y0.9675
X-1.2912Y0.9866
X-1.2765Y1.0055
X-1.2616Y1.0242
X-1.2463Y1.0427
X-1.2308Y1.0610
X-1.2150Y1.0791
X-1.1989Y1.0969
X-1.1825Y1.1146
X-1.1659Y1.1319
X-1.1490Y1.1490
X-1.1319Y1.1659
X-1.1146Y1.1825
X-1.0969Y1.1989
X-1.0791Y1.2150
X-1.0610Y1.2308
X-1.0427Y1.2463
X-1.0242Y1.2616
X-1.0055Y1.2765
X-0.9866Y1.2912
X-0.9675Y1.3056
X-0.9482Y1.3197
X-0.9287Y1.3335
X-0.9090Y1.3469
X-0.8892Y1.3601
X-0.8692Y1.3730
X-0.8491Y1.3855
X-0.8288Y1.3978
X-0.8084Y1.4097
X-0.7878Y1.4213
X-0.7671Y1.4325
X-0.7464Y1.4435
X-0.7254Y1.4541
X-0.7044Y1.4644
X-0.6833Y1.4743
X-0.6622Y1.4840
X-0.6409Y1.4933
X-0.6196Y1.5023
X-0.5982Y1.5109
X-0.5767Y1.5192
X-0.5552Y1.5272
X-0.5336Y1.5349
X-0.5120Y1.5422
X-0.4904Y1.5492
X-0.4688Y1.5559
X-0.4471Y1.5623
X-0.4255Y1.5683
X-0.4038Y1.5740
X-0.3821Y1.5794
X-0.3605Y1.5845
X-0.3389Y1.5893
X-0.3173Y1.5937
X-0.2957Y1.5979
X-0.2742Y1.6017
X-0.2527Y1.6052
X-0.2312Y1.6085
X-0.2098Y1.6114
X-0.1885Y1.6140
X-0.1672Y1.6164
X-0.1460Y1.6184
X-0.1249Y1.6202
X-0.1038Y1.6217
X-0.0829Y1.6229
X-0.0620Y1.6238
X-0.0412Y1.6245
mbellon:
X-0.0206Y1.6249
X0.0000Y1.6250
G0Z0.2000
G0Z1.7000
G0X0.0000Y0.0000
M30
Timman
October 8, 2015, 8:36pm
17
This is my code for just a basic circle cutout in 1/2 foam board
mbellon
(Mark Bellon)
October 8, 2015, 8:55pm
18
G0Z1.7000H1 <- This could be a problem if the stock is very thick; the Nomad has limit z (3"?)
G0X0.0000Y1.6250Z0.2000 <- Z=0.2
G1Z-0.1250F30.0 <- Z=0.125
G1Z-0.2500F30.0 <- Z=0.25
G0Z0.2000 <- This the prolog
G0Z1.7000 <- We see the reverse of the epilog
G0X0.0000Y0.0000 <- go "home"
M30 <- “stop”
There isn’t a lot of Z motion here. This shouldn’t go through with Z0 @top of stock - as long as the stock is 0.25" thick or more. You’re 0.5".
You should turn on G02/G03 support in the post processor - this would be a lot smaller!
This isn’t a CAD or CAM issue. If you’re sure you did “touch top (of stock)” to set Z0 there should be no issues with 0.5" stock. Since you’re going through the stock, this appears to be a set up issue with the Z travel of the machine. Time for a support call!
Timman
October 8, 2015, 9:28pm
19
Thanks for all the help guys, I was kinda thinking it was not my code or the post processing.
Guess I am making the call
Jamesrs
(Jim Shelton)
October 12, 2015, 12:41pm
20
Hello
I had a similar problem, whereas I was working in imperial and the Carbide control was metric. I had contacted Edward he had sent me a script for the Shapeoko 3 to show up in the machines on the Vectric product. I’d send it but I’m at work
