I can't add a bit in Carbide Create Pro
Hi :slight_smile: ,
Sorry for my English, I use a translator I come from France.
I want to add a bit to my library, but I encounter a bug. Already, when I click on diameter, I cannot use the delete key, I have to select everything to be able to delete afterwards (which is not serious, I wanted to warn you). In addition, the point is not accepted (whether i enter the tool in inches or mm), but I can put a comma.
But my problem is that when I want to validate, it highlights the angle, as if I had forgotten to fill it in and it is mandatory. The problem is that there is none on this bit, so I can’t select it to write 0. I don’t know if it’s the point that’s causing the problem?
I’m in a lot of trouble because I can’t add my tools that don’t have angles. I hope you can help me !
Thanks
Software: Carbide creator pro V777
CNC: shapeoko 5 pro
You will need to change your decimal separator from a comma to a period in order to directly create/alter tools.
This is usually a localization/user preference setting.
IIt works, thanks for helping me so quickly. I still hope that the administrators will sort this out in the future.
Thanks again for helping!
