I have a 4x4 shapeoko 5 pro with leg kit. I am looking at replacing the hybrid table with a vacuum table and would like a Drawing of the current hybrid table so I can place the screws in the same location for the MDF board I am using. I will bolt the MDF straight to the frame instead of the clamp tracks. I am cutting weak materials and the clamps/glue just are not holding the material well enough. Screws are holding the material in place but is not ideal.
This gives the Y location but not the X of the location of the screws.
I went down this road (rabbit hole) on the 2 x 4. tldr, I had to jog slash probe manually around the table to find and record each of them.
The issue was even with a full technical drawing, there are slight tolerances in how the holes are milled and how the extrusions butt up to each other when its assembled.
I used this file as a starting point for the extrusion spacing but it excludes the bolts. Then I overlaid the MDF Slats from the other file on to it https://cutrocket.com/p/646b89e7aca13
For the probing what I did was to set XY 0 at the absolute SW corner. Then remove the slats, chuck a 1/4" steel pin, then manually jog around the table and microjog until the pin dropped in the hole cleanly. I think it just worked out that the inner thread of the bolt holes was very close to 1/4".
When I drew that all up, it was absolutely not a perfect 90 degree grid. Some holes were .020" out from the theoretical grid. I split the difference in some cases and it works with MDF. I make these combo locating spoilboard from MDF I direct mount to the table for different jobs.
I did this right when I got the machine, when I didn’t understand it well. I would love to know a better way to do this
You could use Dowel Centers / Dowel Tenon Centers (For Blind or Open Holes) or Transfer Screws to locate the center of the holes precisely. Of course, you’d end up cutting each slat hole by hand drill…but it wouldn’t be THAT bad.
I will keep a eye out on the square. I had considered leaving most of the metal hybrid track in place and putting the mdf on top and only removing 2 of the Tracks for the vacuum hook ups to connect. but would still need bolt hole pattern. And 4wm thanks for the starting point file, I might be able to make that work combined with the slats file.
I thought you meant making something like an air weights table but mounted direct to the aluminum. Heres what I’m describing. The MDF slats were removed and thinned on a thickness sander to be flush with the top of the extrusions.
You don’t need the bolt hole patter at that point. You just need to use the t slots and t nuts to hold it down with bolts through the plenum into the t nut.
My reason is to be able to swap different project specific fixtures on and off to known coordinates on the table. Its useful in guitar making but agree not neccesary for an all purpose vacuum table.
The ability to use jigs and a functional vac table is a constant battle.
I make jigs that have lips to locate on the left front corner of the vac table. I can then either use the vac table to hold the jig in place, or I can use some clamps in the t slots in the black extrusions if the jig will be there for awhile either works.
If you worried about locational accuracy you cannot two holes at known locations in the jig then use a broken end mill or ground rod in the spindle to check those locations
Thanks. I surely under-utilize the T Nuts and tracks. I’m not using a vac now so that’s the difference for me. My fixtures are big MDF slabs. A 24" x 36" fits 3 guitar necks easily probably could fit 4. Locating pins with double side tape. At that size clamping only at edges isn’t enough to prevent the center from flexing. That’s why I started bolting direct to the table to hold the MDF down. I never thought to do that with recessed bolts into T Nuts in the tracks. Just would be more fiddly to get them in the right spot mid table under the MDF Great thing about this forum is finding new ways to do something. What I really need is a combination vacuum / spoilbaord / locating fixture but i won’t hijack this thread any further about.
You could design a custom t-nut, that has a removable pin, that you can use as your reference. Build it so it is level to the top of the track, and leave it in place.
