Hi,
Can I use ArtCAM to do 3D machining on my shapeoko pro?
Hi,
Yes, if you can find a post-processor which will work — ideally there would be one for our machines, if that’s not an option, is Grbl (which is the firmware we use) an option?
If neither of those, LinuxCNC would work (the Grbl folks use it as a reference implementation), and if that isn’t an option, try Mach3 — if none of those are to be found, “Basic G-Code” or whatever is the simplest and most basic G-Code output option.
thanks you man, I going to prove it
