This is my first time using Carbide Create. I have a image with a outside offset that is inside a box offset. When I select both the image offset and the box offset and do a pocket with a 1/4 bit, it pockets the whole box and ignores the image offset. I do not want the image included in the pocket.
How do I do this??
Thanks for the help.
Dan
Which version of Carbide Create are you using?
Please post the file you are having trouble w/ and we’ll do our best to assist.
Ok… I figured it out. If the offset of the image crosses the offset of the box it is in, it causes problems with the pocket. Because of the image and the box, I’m going to have to take the image apart and make sure each section of the image fits.
I guess I thought CC would somehow figure it out.
Thanks for the help…
