Is there a way to import cc pro files?
I found an eagle carving at cutrocket under the signs category but it requires pro to open.
Is there someway to use these files with cc or they only work on the pro version?
Thanks,
Pete
Thanks,
Pete
A file saved from Pro can only be opened in Pro.
It should work to put your copy into Pro’s Trial mode, delete the 3D model, then re-save under a new name, exit the Trial mode, then the file should open w/o the Pro license — if that doesn’t work, export the geometry to an SVG and import into a new file.
