I have a fusion 360 file and I want to extract 1 of the parts from it. I have the option of downloading the file in different formats. What is the best format to import in CC?
Hi @Jaap,
DXF is the answer, but rather than exporting the project you will likely want to export a single sketch (that has the 2D contours you want to import in CC). Right-click on a sketch, and “Save as DXF”
