Is there a way to get the various library items (Christmas, 4th of July, teddy bears, etc…) imported via the ‘Model>Import Image’ 3D section? I am on a Mac and for the life of me I cant find the directory where these images are kept. What I ended up doing was taking a screenshot of what I needed, took that into photoshop to clean it up, then created a STL file (free online page), then imported it as an STL…
I am hoping there is an easier and more cleaner way to do this.
Thanks
Import image is mostly for greyscale. If you wanted to use the vector from the library items you could just import them into the workspace (size/rotate as needed) and then go to the model tab and select the vector and then the option for “add shape”. This will allow you to set different parameters like giving things a round bubble look, or flat simple extrude.
Ah… Thanks!
I didn’t realize the create shape could work this way, I thought it was just for, well, creating a shape…
Thank you, this is exactly what I was looking for … this, in combination with carving the vector lines of the image later in 2D will work great. ![]()
