Importing IDC tool database
How ccan I import the IDC tool database into CC Pro V7? The file opens as a spreadsheet, I hope that does not mean I have to make the entries manually.
The custom C3D database of tools is a .csv file. So if you can open the IDC tool database in a spreadsheet you can save it as a .csv file. Then you will have to make the fields in the custom C3D database match up to the fields in the IDC file. It is unlikely the IDC database (.csv file) will be the same as the C3D format in the order of the fields…
It will likely be some manual work.
Thanks Guy, appreciate the response
