Importing or default Layers?
Is there a way to either import layers or setup a set of default Layers? A lot of the jobs I am doing require the same 4 or 5 Layers and making and configuring the each time I start a project just adds time to creating the files. Is there a better way to do this?
If you save an empty file with the layer setup, you can import it & it will bring in the layers.
Or you could use a seed part. Same template file saved with layers. Open it & Save As… your new project file.
Thanks Tod1d, one of those methods should work for me.
