tjandt
(Tim Jandt)
1
I’ve been doing some research to try and increase the speed of the Z-Axis on my XXL through changing the GRBL settings.
I’ve never done this, and am wondering if anyone has made any changes? I think I found the correct setting to change, $112 - Z Max Rate mm/min
Right now, it looks like the max rate is set to 1000mm/min or about 40 in/min (Vcarve uses in/min).
Can anyone confirm if $112 is the right setting to change, and has anyone had experience doing this?
Thanks!
Tim
neilferreri
(Neil Ferreri Ω)
2
That’s the correct setting. Be sure to do some tests to make sure your Z axis can handle the speed.
tjandt
(Tim Jandt)
3
Thanks! I’ll try some tests out on scrap wood of the same species I plan on drilling to be sure it works. Appreciate the reply.
system
(system)
Closed
4
