The z axis switch is not working. LED does not light up. I will replace but does anyone know if its possible to replace this switch with a mechanical switch in the meantime?
Thanks,
Joseph
Thanks,
Joseph
If you can connect the mechanical switch and mount it, yes, but contact support@carbide3d.com and we’ll get a replacement to you as quickly as we can.
Hi Will, I’ve sent in a request and called but havent gotten an awnser. In the meantime do you have a wiring diagram?
There are 3 wires going intot the switch. blue brn blk. Im in the middle of a project that i need to finish tomorrow.
Thanks,
Joseph
Ok so its blue wire (signal?) to black wire(ground) to close switch. 3d printing a mount now. Hope to hear from support soon!
Thanks,
Joseph
