Anyone have the info for cutter 501 and 502 so they can be added to the tool library of carbide creat. Thank you.
Note that they are in CC451 (possibly earlier versions):
(note that the flute length isn’t correct, please adjust as need be)
Please note that these are intended for PCB engraving — you’ll need to work around the rounded tip when setting zero, and the actual toolpath for Carbide Create won’t take that rounding into account.
