Initialize and z axis
Just started my new machine to initialize and the router dove to the waste board. I have a 4 xl and can not get it to initialize to the right corner. All the wires are correct but the z axis still wants to bottom out to the bottom.
Connect to the machine, BEFORE you initialize, resend the configuration. Make sure you pick the correct Z if there is a choice.
Z diving means EITHER the wiring is backwards or you have the wrong configuration loaded.
Thanks, just downloaded 551 cm and will resend the configuration to the machine.
