Insert for the 65mm standard router
Does anyone know where I can get the insert so I can put the 65mm standard compact router into my Shapeoko XL?
Have you checked in with support@carbide3d.com ?
If we’re out, you can make them using a suitable piece of aluminum tubing — the Imperial size is usually a bit thin walled (it will work, but the mount will be deformed a bit), while the Metric is should be about perfect.
